查看: 4076|回复: 3
[求助] 初学uvm的问题
发表于 2022-8-18 21:45:22 | 显示全部楼层 |阅读模式
Following verilog source has syntax error :
          Token 'uvm_driver' should be a valid type. Please check whether it
  is misspelled, not visible/valid in the current context, or not properly
  imported/exported.
  "my_driver.sv", 1: token is ';'
  class my_driver extends uvm_driver;
请问这个错误怎么处理啊?
发表于 2022-8-19 08:05:48 | 显示全部楼层
1.cmd里要把uvm库吃进来;
2.代码里要import uvm pkg
 楼主| 发表于 2022-8-19 08:12:29 | 显示全部楼层
uestc_zyd 发表于 2022-8-19 08:05
1.cmd里要把uvm库吃进来;
好的,我试试
发表于 2023-9-5 11:14:31 | 显示全部楼层
请问一下解决了嘛 我也遇到了同样的问题
GMT+8, 2025-12-21 21:19 , Processed in 0.517172 second(s), 5 queries , Gzip On, Redis On.
