楼主: zhushining
SNPS license 版本
发表于 2022-7-30 04:01:24 | 显示全部楼层
How can I see the content?
发表于 2022-7-30 14:12:17 | 显示全部楼层
SCL_2018.06-SP1 应该可以
Verdi (R)
Release Verdi_Q-2020.03-SP1 for (RH Linux x86_64/64bit) -- Sun May 31 02:50:02 PDT 2020
Copyright (c) 1999 - 2020 Synopsys, Inc.
This software and the associated documentation are proprietary to Synopsys, Inc.
This software may only be used in accordance with the terms and conditions of a written license agreement with Synopsys, Inc.
All other use, reproduction, or distribution of this software is strictly prohibited.
rcfile = /EDA/tools/synopsys/verdi/Q-2020.03-SP1/etc/novas.rc
*WARN* Cannot open /home/xxx/novas.conf for read access. No such file or directory
guiConfFile (read)= N/A (default)
guiConfFile (write)= /home/xxx/novas.conf (working directory)
发表于 2022-7-30 14:24:26 | 显示全部楼层
换SCL版本
发表于 2022-8-1 09:31:02 | 显示全部楼层
zhushining 发表于 2022-7-29 22:32
scl 2018和2021 都不行
scl也需要patch才可以
发表于 2022-8-1 09:49:50 | 显示全部楼层
同问
发表于 2022-8-1 09:59:48 | 显示全部楼层
谢谢分享
 楼主| 发表于 2022-8-1 15:14:24 | 显示全部楼层
发表于 2022-8-2 17:43:43 | 显示全部楼层
http://www.sd173.com/soft/9589.html
https://bbs.eetop.cn/thread-879031-1-2.html
Please read and follow the link above carefully.
Here's the answer.
And the SCL version must also be up to date.
GMT+8, 2025-12-25 11:48 , Processed in 0.019610 second(s), 4 queries , Gzip On, Redis On.
