查看: 6753|回复: 17
SNPS license 版本
发表于 2022-7-28 21:38:52 | 显示全部楼层 |阅读模式
悬赏30资产未解决
Release Verdi_Q-2020.03 for (RH Linux x86_64/64bit) -- Sun Feb 9 05:01:42 PDT 2020
Copyright (c) 1999 - 2020 Synopsys, Inc.
This software and the associated documentation are proprietary to Synopsys, Inc.
This software may only be used in accordance with the terms and conditions of a written license agreement with Synopsys, Inc.
All other use, reproduction, or distribution of this software is strictly prohibited.
rcfile = /home/rock/novas.rc
guiConfFile (read)= /home/rock/novas.conf (working directory)
guiConfFile (write)= /home/rock/novas.conf (working directory)
[SCL] Error:  One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
[ERROR] Could not checkout Verdi license. Use verdi -licdebug for more information.
license 版本太低了怎么办
发表于 2022-7-29 00:46:04 来自手机 | 显示全部楼层
安装新一点的scl试试
发表于 2022-7-29 10:05:19 | 显示全部楼层
scl2018确定可以。11.10是2015的吧,不行
发表于 2022-7-29 14:07:39 | 显示全部楼层
Q-2020.03安装后的磁盘文件夹可否共享一下,我可以给你1k信元,谢谢
发表于 2022-7-29 15:31:56 | 显示全部楼层
为啥不要安装包,要安装后的文件夹呢?这个应该不能直接移植安装文件夹使用吧
 楼主| 发表于 2022-7-29 22:22:51 | 显示全部楼层
seabeam 发表于 2022-7-29 00:46
安装新一点的scl试试
SCL 已经是2021.12
 楼主| 发表于 2022-7-29 22:32:03 | 显示全部楼层
scl 2018和2021 都不行
发表于 2022-7-29 23:02:27 | 显示全部楼层
2018以前license文件用不了,2020版的license加密方式不一样,需要重新破解生成
发表于 2022-7-30 01:56:33 | 显示全部楼层
西门村村 发表于 2022-7-29 15:31
为啥不要安装包,要安装后的文件夹呢?这个应该不能直接移植安装文件夹使用吧 ...
最好有安装包,但是一般不愿意共享安装包,退而求其次试试看安装后文件夹能不能用吧。
发表于 2022-7-30 03:27:25 | 显示全部楼层
thx...
GMT+8, 2025-12-9 03:28 , Processed in 0.021723 second(s), 3 queries , Gzip On, Redis On.
