查看: 8993|回复: 25
[资料] Optimized Split Capacitive Array in 16-Bit SAR ADC with Redundancy
发表于 2022-7-15 18:30:35 | 显示全部楼层 |阅读模式
Fan, H., Lei, P., Feng, Q. et al. Optimized Split Capacitive Array in 16-Bit SAR ADC with Redundancy. Circuits Syst Signal Process (2022). https://doi.org/10.1007/s00034-022-01955-2
This paper presents an area-efficient split capacitive array architecture for high-resolution successive approximation register (SAR) analog-to-digital converters (ADCs). The equivalent value method is proposed to adjust the bridge capacitance as an integer value so that the bridge capacitance can match well with the unit capacitance. A split capacitive array with redundancy is utilized in a 16-bit SAR ADC and the total required number of the unit capacitors is only 452. Four proposed static pre-amplifiers enhance the noise performance and the offset performance of the comparator and a proposed dynamic latch enhances the speed performance. As a result, the 180 nm design can achieve a 1 MS/s sampling rate with a single channel. The spurious-free dynamic range is 105.85 dB while the effective number of bits can reach 15.78 bits with a Nyquist-rate input while consuming 32 mW from a 5 V supply. The resultant Schreier and Walden figures of merit are 168 dB and 457 fJ/conversion-step respectively. The proposed SAR ADC occupies an active area of 4200 \(\upmu \mathrm{m}\) by 2200 \(\upmu \mathrm{m}\).
谁帮忙下载一下这篇文章呢?好像是成都华威电子公司做的,指标非常好啊,想学习学习。
发表于 2022-7-16 22:12:44 | 显示全部楼层
如附件所示。
Fan2022_Article_OptimizedSplitCapacitiveArrayI.pdf
1.95 MB, 下载次数: 269 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-7-16 22:39:56 | 显示全部楼层
meidinlei 发表于 2022-7-16 22:12
如附件所示。
thanks,
发表于 2022-7-16 23:48:29 | 显示全部楼层
thanks,
发表于 2022-7-17 15:28:16 | 显示全部楼层
这面积4.2*2.2 mm ^2不小啊
 楼主| 发表于 2022-7-18 10:53:26 | 显示全部楼层
如附件所示。
谢谢,感谢!!!
发表于 2022-7-18 13:20:51 | 显示全部楼层
看下,学习理解下。
发表于 2022-7-18 13:25:55 | 显示全部楼层
学习了。。。
发表于 2022-7-18 15:47:17 | 显示全部楼层
谢谢分享
发表于 2022-7-18 16:19:46 | 显示全部楼层
GMT+8, 2025-12-29 06:27 , Processed in 0.020277 second(s), 4 queries , Gzip On, Redis On.
