查看: 3029|回复: 6
Design Procedure for 2Stage CMOS OPA...
发表于 2008-1-5 13:29:05 | 显示全部楼层 |阅读模式
Design Procedure for Two-Stage CMOS Opamp With Flexible Noise-Power Balancing Scheme
Abstract—This paper presents a basic two-stage CMOS opamp
design procedure that provides the circuit designer with a means
to strike a balance between two important characteristics in
electronic circuit design, namely noise performance and power
consumption. It is shown in this paper that, unlike the previously
reported design procedures, the proposed design step allows
opamp designers to trade between noise performance and power
consumption with greater flexibility. In order to verify the viability
of the proposed design step, SPICE simulation results of the
opamp designed by the proposed procedure, under a variety of
temperature and process conditions, are given.
Index Terms—CMOS analog integrated circuits, frequency compensation,
operational amplifier, poles and zeroes.
Design Procedure for Two-Stage CMOS OpampWith Flexible Noise-Power Balancing Scheme.pdf
358.5 KB, 下载次数: 64 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-5 23:26:30 | 显示全部楼层
不错的咚咚,坐个沙发!
发表于 2008-1-6 05:37:26 | 显示全部楼层
发表于 2008-1-8 00:22:49 | 显示全部楼层
好东东,顶一下
发表于 2008-1-8 00:24:41 | 显示全部楼层
再次定一下
发表于 2008-3-3 17:11:02 | 显示全部楼层
谢谢!
楼主辛苦了。
发表于 2008-6-1 02:29:31 | 显示全部楼层
很棒的資料
馬上下來參考看看
謝謝
GMT+8, 2025-12-20 10:37 , Processed in 0.026503 second(s), 7 queries , Gzip On, Redis On.
