查看: 2835|回复: 2
[求助] siliconsmart 启动 报错
发表于 2022-6-1 14:29:42 | 显示全部楼层 |阅读模式
伙伴们好,我通过EDA虚拟机安装了silicon smart 工具,启动时候报错,具体内容如下:
Info: Thu Apr 27 23:33:59 2017: Establishing connection to license server
Error: Thu Apr 27 23:33:59 2017: Unable to check out license FEATURE SIS_BASE_CLIENT
License std_client is not available. Make sure that SNPSLMD_LICENSE_FILE or LM_LICENSE_FILE has the correct license path
Info: Maximum virtual memory size: 558.102 MB
CSDN上有伙伴说是因为 “由于Synopsys 用 keygen 生成的license,不支持siliconsmart”
但我不知道该怎么修改license,有大神帮忙一下哈
发表于 2022-8-11 15:33:38 | 显示全部楼层
解决了吗楼主?同样的问题。求解111
发表于 2022-8-16 09:50:11 | 显示全部楼层
楼主求解
GMT+8, 2025-12-23 12:32 , Processed in 0.013069 second(s), 3 queries , Gzip On, Redis On.
