查看: 3009|回复: 7
[原创] 根据论文,运用tsmc18rf实现0.3V 轨对轨 低功耗OTA
发表于 2022-5-10 20:25:48 | 显示全部楼层 |阅读模式
值得提出的是文章使用衬底驱动,觉得挺有意思。
文章摘要:A new solution for an ultra-low-voltage, ultra-low-power operational transconductanceamplifier (OTA) is presented in the paper. The design exploits a three-stage structure with a ReversedMiller Compensation Scheme, where the input stage is based on a non-tailed bulk-driven differential pair.Optimization of the structure for very low supply voltage is discussed. The resulting amplifier outperformsother ultra-low-voltage OTAs in terms of a DC voltage gain and power efficiency, expressed by standardfigures of merit. Experimental verification using a 0.18 µm CMOS technology, with supply voltage of 0.3-V,showed a dissipation power of 13 nW, a DC voltage gain of 98 dB, a gain-bandwidth product of 3.1 kHzand an average slew-rate of 9.1 V/ms at 30 pF load capacitance. The experimental results agree well withsimulations.
资料是IEEE网站中作者发布的文章和用candence实现原理图仿真。
仿真图片如下:
1.开环增益:
2.共模输入范围:
3.共模抑制比
有兴趣可以仿仿别的参数,比如转换速率,电源抑制比,环路增益(stb)
A_0.3-V_98-dB_Rail-to-Rail_OTA_in__0.18mu_m_CMOS.pdf
8.04 MB, 下载次数: 97 , 下载积分: 资产 -4 信元, 下载支出 4 信元
文章
three_OTA.zip
354.24 KB, 下载次数: 65 , 下载积分: 资产 -2 信元, 下载支出 2 信元
candence原理图仿真
发表于 2022-5-11 08:57:21 | 显示全部楼层
谢谢分享
发表于 2022-5-11 15:22:49 | 显示全部楼层
发表于 2022-5-11 19:30:53 | 显示全部楼层
仿真了一下,竟然只有13nW的功耗
发表于 2022-5-11 20:43:05 | 显示全部楼层
这个好像是用于生物医疗前端电路的放大器吧,ECG信号频率0.1Hz-100Hz,刚好可以用
发表于 2024-10-7 15:15:53 | 显示全部楼层
thanks
发表于 2024-10-15 17:50:15 | 显示全部楼层
谢谢分享
发表于 2025-2-10 21:26:22 | 显示全部楼层
感谢分享
GMT+8, 2025-12-27 19:16 , Processed in 0.025142 second(s), 5 queries , Gzip On, Redis On.
