查看: 3331|回复: 11
[求助] 有源滤波器
发表于 2022-5-10 14:17:50 | 显示全部楼层 |阅读模式
仿真有源滤波器工艺角时发现截至频率变化很大,最大误差50%,有没有什么办法解决呢,或者怎样去进行频率补偿,用的是TSMC65nm工艺,当电阻电容都是ff类型时,误差50%
发表于 2022-5-10 15:08:37 | 显示全部楼层
use mos as cap and add RC-calibration
 楼主| 发表于 2022-5-10 17:17:40 | 显示全部楼层
how to add RC-calibration
发表于 2022-5-10 18:27:35 | 显示全部楼层
 楼主| 发表于 2022-5-10 18:32:56 | 显示全部楼层
can you share more information,thanks vrey much
发表于 2022-5-10 19:00:15 | 显示全部楼层
if something is not clear in picture, I can explain, I used this idea many many times and it worked great for filters. you just need to charge cap by reference current for a few cycles of ref clock and then compare Vcap to voltage drop across res Vres. when Vcap gets higher Vres it means that Tref=Cap*Res, and res mism is compensated by trim capacitance.
发表于 2022-5-10 19:02:13 | 显示全部楼层
in not, just increase trim cap and try again
 楼主| 发表于 2022-5-11 11:12:12 | 显示全部楼层
LoktikVJ 发表于 2022-5-10 19:00
if something is not clear in picture, I can explain, I used this idea many many times and it worked  ...
如何控制电容是充电还是放电呢,图中mos管旁边的反相器作用是什么?谢谢!
发表于 2022-5-11 15:23:19 | 显示全部楼层
added small update, check timig dig with phases, signal mode controls charge time, then switch current for Vres generation. in the end of cycle disharge cap.
 楼主| 发表于 2022-5-11 16:18:31 | 显示全部楼层
LoktikVJ 发表于 2022-5-11 15:23
added small update, check timig dig with phases, signal mode controls charge time, then switch curre ...
can you share this paper?
GMT+8, 2025-12-29 01:29 , Processed in 0.021496 second(s), 4 queries , Gzip On, Redis On.
