查看: 12898|回复: 48
Continuous-Time Filters from 0.1Hz to 2.0GHz
发表于 2008-1-4 11:58:28 | 显示全部楼层 |阅读模式
Abstract.-The bipolar transconductance amplifier (OTA) was commercially introduced in
1969 by RCA. Designers began using OTAs in the middle 80’s, since then the CMOSOTA
has becoming a vital component in a number of electronic circuits, both in open
loop and in closed loop applications. Here, we will focus on open loop applications.
Continuous-time filters implemented with transconductance amplifiers and capacitors
known as Gm-C or OTA-C are very popular for a host of applications. These applications
involve frequency of operation from a few tents of a hertz up to several gigahertz. Several
of those applications are in medical electronics and seismic area where the frequency
range is between 0.1Hz up to 20Hz. Other applications in the audio range do not
commonly use OTA-C filters because switched-capacitor techniques excel in this range.
But for frequency range of a few MHz like in Intermediate Frequency (IF) filters in RF
receivers OTA-C implementations are very attractive. For a few GHz range applications
where the OTA becomes a simple differential pair there is number of researchers
investigating LC-oscillators and filters. In this tutorial we discuss practical
implementations of transconductance amplifiers oriented for wide range of applications
for example in medical, IF filters, hard disk drive linear phase filters, LC-oscillators and
RF filters. Furthermore the unavoidable tuning scheme to compensate the Gm/C
deviations due to process technology variations is discussed. OTA single ended, fully
differential and pseudo differential versions are introduced together with the commonmode
feedback circuits needed for proper operation of differential architectures.
Tutorial.rar
1.23 MB, 下载次数: 109 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-4 12:07:16 | 显示全部楼层
good good good
 楼主| 发表于 2008-1-4 12:29:03 | 显示全部楼层
自己頂
发表于 2008-1-4 13:18:07 | 显示全部楼层
不错不错!!!!
发表于 2008-1-4 13:19:08 | 显示全部楼层
期待ing
发表于 2008-1-4 22:12:29 | 显示全部楼层
Gooooood!
 楼主| 发表于 2008-1-6 13:33:29 | 显示全部楼层
push by my self
 楼主| 发表于 2008-1-7 16:48:15 | 显示全部楼层
我再頂
 楼主| 发表于 2008-1-9 16:46:33 | 显示全部楼层
我再頂
发表于 2008-1-10 01:00:01 | 显示全部楼层
Thanks!
GMT+8, 2025-12-22 19:04 , Processed in 0.025628 second(s), 6 queries , Gzip On, Redis On.
