查看: 5263|回复: 8
[求助] charge pump + NMOS LDO 求助
发表于 2022-5-5 14:45:26 | 显示全部楼层 |阅读模式
求助,大家有没有用charge pump 抬高NMOS 栅压的LDO资料论文啊? 求分享~
发表于 2022-5-5 14:54:46 | 显示全部楼层
ST的103里面capless LDO就是这么做的。
 楼主| 发表于 2022-5-5 15:02:34 | 显示全部楼层
有paper可以直接看的嘛?
发表于 2022-5-6 15:52:20 | 显示全部楼层
2018_A 1.24 μ A Quiescent Current NMOS Low Dropout Regulator With Integrated Low-Power Oscillator-Driven Charge-Pump and Switched-Capacitor Pole Tracking Compensation
Published in: IEEE Journal of Solid-State Circuits ( Volume: 53, Issue: 8, Aug. 2018)
Abstract:
Supply regulation using low quiescent current linear regulators helps in extending the battery life of power aware applications with very long standby time. A 1.24 μA quiescent current NMOS low dropout (LDO) that uses a hybrid bias current generator (HBCG) which boosts the bias current dynamically and adaptively to improve the transient response is presented in this paper. A bias-current scalable error amplifier with an on-demand pull-up/pull-down buffer drives the NMOS pass device. The error amplifier is powered with an integrated dynamic frequency charge pump to ensure low dropout voltage. A low-power relaxation oscillator (LPRO) generates the charge pump clocks. A novel switched-capacitor pole tracking (SCPT) compensation scheme is proposed to ensure stability up to maximum load current of 150 mA with a low-ESR 1 μF output capacitor. Designed in a 0.25 μm CMOS process, the LDO has an output voltage range of 1-3 V, a dropout voltage of 240 mV, and a core area of 0.11 mm 2 .
发表于 2022-5-6 16:02:24 | 显示全部楼层
2018 PhD(ASU)_Ultra-low Quiescent Current NMOS Low Dropout Regulator With Fast Transient response for Always-On Internet-of-Things Applications
2018 PhD(ASU)_Ultra-low Quiescent Current NMOS Low Dropout Regulator With Fast T.pdf
2.51 MB, 下载次数: 243 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-5-6 16:06:27 | 显示全部楼层
2009_On-chip low drop-out voltage regulator with NMOS power transistor and dynamic biasing technique
2009_On-chip low drop-out voltage regulator with NMOS power transistor and dynam.pdf
693.62 KB, 下载次数: 170 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-5-6 21:23:29 | 显示全部楼层
sunjimmy 发表于 2022-5-6 16:02
2018 PhD(ASU)_Ultra-low Quiescent Current NMOS Low Dropout Regulator With Fast Transient response fo ...
多谢分享
发表于 2024-1-29 15:26:01 | 显示全部楼层
1111111111
发表于 2024-10-19 19:53:50 | 显示全部楼层
thanks
GMT+8, 2025-12-25 08:55 , Processed in 0.241994 second(s), 4 queries , Gzip On, Redis On.
