查看: 2454|回复: 2
[原创] ITU G781 以太网时钟同步的标准
发表于 2022-5-3 07:47:05 | 显示全部楼层 |阅读模式
Synchronization layer functions for frequency synchronization based on the physical layer
Recommendation ITU-T G.781 defines the atomic functions that are part of the two synchronization layers, the synchronization distribution (SD) layer and the network synchronization (NS) layer. It also defines some atomic functions, part of the transport layer, which are related to synchronization.
These functions describe the synchronization of SDH, Ethernet, and OTN NEs and how these NEs are involved in network synchronization.
The specifications in this Recommendation are the superset of functionality of three regional standards bodies. Care should be taken when selecting from this Recommendation.
Not every atomic function defined in this Recommendation is required for every application. Different subsets of atomic functions may be assembled in different ways according to the combination rules given in Recommendations ITU-T G.783, ITU-T G.705, ITU-T G.8021, ITU-T G.8121, and ITU-T G.798 to provide a variety of different capabilities. Network operators and equipment suppliers may choose which functions must be implemented for each application.
T-REC-G.781-202004-I!!PDF-E.pdf
4.9 MB, 下载次数: 24 , 下载积分: 资产 -3 信元, 下载支出 3 信元
时间同步
发表于 2022-5-3 21:52:32 | 显示全部楼层
kanakna
发表于 2022-5-4 11:05:16 | 显示全部楼层
感谢楼主分享!
GMT+8, 2025-12-23 16:40 , Processed in 0.014759 second(s), 5 queries , Gzip On, Redis On.
