查看: 3676|回复: 5
[求助] 请问怎么用liberty文件生成verilog文件?
发表于 2022-4-28 11:35:10 | 显示全部楼层 |阅读模式
似乎老版本library compiler可以用下面这个命令生成verilog
'write_lib -format verilog'
但2018版会报错说format只能选db
请问各位大佬verilog文件要怎么生成呢?想ptpx用
发表于 2022-4-28 14:39:27 | 显示全部楼层
如果你是缺db的话,lib可以生成db,用lc_shell  read_lib .lib  write_lib name -f db -o .db
 楼主| 发表于 2022-4-28 16:46:57 | 显示全部楼层
Lotusy 发表于 2022-4-28 14:39
如果你是缺db的话,lib可以生成db,用lc_shell  read_lib .lib  write_lib name -f db -o .db ...
db是有的,但是想生成verilog库。
发表于 2022-4-29 15:10:30 | 显示全部楼层
ncx:
Generating Verilog Files
Library Compiler generates a Verilog model from a .lib file and creates a cell.v Verilog file for each cell in the library. By default, Library Compiler creates the cell.v files in the user-defined library_name_verilog directory, under the current working directory. If the library_name_verilog directory already exists under the current working directory, the newly generated cell.v files overwrite the existing files in the directory, and Library Compiler issues a warning message.
Use the following commands to generate Verilog models:
1.To enable Verilog model generation, set the veriloglib_enable variable to true. By default, the variable is set to false, and a Verilog file is not generated.
set veriloglib_enable [true | false]
2.To create a Verilog file from a .lib file, run the write_lib command in lc_shell and specify the .lib library name as shown:
write_lib -format verilog library_name
 楼主| 发表于 2022-5-6 15:49:40 | 显示全部楼层
Lotusy 发表于 2022-4-29 15:10
ncx:
Library Compiler generates a Verilog model from a .lib file and creat ...
多谢回复,但我用的lc2018版本这样操作会报错
发表于 2025-3-15 09:15:59 | 显示全部楼层
请问这个报错最后怎么解决的,我目前遇到了同样的报错,谢谢
GMT+8, 2025-12-27 15:31 , Processed in 0.015691 second(s), 4 queries , Gzip On, Redis On.
