查看: 2169|回复: 2
[求助] hspice仿真意外中断,怎么恢复仿真
发表于 2022-4-20 09:22:02 | 显示全部楼层 |阅读模式
VNC意外挂了,仿真也中断了。仿真了一星期了,怎么让仿真继续?不想重新开始。。
发表于 2022-4-20 11:13:33 | 显示全部楼层
长时间的仿真最好保存中间节点
发表于 2022-4-21 09:32:10 | 显示全部楼层
You can refer hspice manual
Chapter 13: Transient Analysis
Storing and Restoring Checkpoint Files
Store/restore is a feature that creates checkpoint files describing a running
process during transient analysis; the operating system can later reconstruct
the process from the contents of this file. This feature is not supported HSPICE
advanced analog analyses.
Note: The -restore operation should be submitted on a machine that
has the same kernel version as the machine used to store,
otherwise, a failure may occur.
The following sections discuss these topics:
■ Store by Using the .STORE Command
■ Store by Interrupting the Simulation Process
■ Restore Operation
■ Usage Requirements
GMT+8, 2025-10-3 13:16 , Processed in 0.327918 second(s), 3 queries , Gzip On, Redis On.
