查看: 7366|回复: 27
Low Supply Voltage CMOS Charge Pumps
发表于 2008-1-2 17:49:46 | 显示全部楼层 |阅读模式
Abstract
Charge pumps that can operate under a low supply voltage
are described. The use of charge transfer switches (CTSs)
can improve the voltage pumping gain. Applying dynamic
control to the CTSs can reduce reverse currents. Appending
bootrapped output stages to the new charge pumps can further
expand the maximum output voltage.
Low Supply Voltage CMOS Charge Pumps.pdf
35.66 KB, 下载次数: 141 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-3 23:27:24 | 显示全部楼层
看看看看看
发表于 2008-1-4 15:42:22 | 显示全部楼层
kan kan zai shuo
发表于 2008-1-5 01:43:32 | 显示全部楼层
Thanks!
发表于 2008-1-8 22:29:05 | 显示全部楼层
感謝大大無私的分享!!
发表于 2008-2-16 02:18:31 | 显示全部楼层
Thanks!!
顶!!
发表于 2008-3-3 12:30:59 | 显示全部楼层
谢谢!
楼主辛苦了。
发表于 2008-3-14 16:06:35 | 显示全部楼层
5字补丁
发表于 2008-3-14 16:12:12 | 显示全部楼层
钱啊钱
发表于 2008-3-14 16:19:32 | 显示全部楼层
天拉.下到中途老断.重下又花钱
GMT+8, 2025-12-21 08:03 , Processed in 0.034941 second(s), 7 queries , Gzip On, Redis On.
