查看: 4917|回复: 8
[求助] 求pci-sig标准文档,Integrity and Data Encryption (IDE) ECN
发表于 2022-4-2 22:41:37 | 显示全部楼层 |阅读模式
悬赏2000资产已解决
pci-sig上需要会员才能下载文档,求下面3个文档。
1. Integrity and Data Encryption (IDE) ECN
2. Integrity and Data Encryption (IDE) ECN – Revision A (Change Bar)
3. Integrity and Data Encryption (IDE) ECN – Revision A
Integrity & Data Encryption (IDE) provides confidentiality, integrity, and replay protection for TLPs. It flexibly supports a variety of use models, while providing broad interoperability. The cryptographic mechanisms are aligned to current industry best practices and can be extended as security requirements evolve. The security model considers threats from physical attacks on Links, including cases where an adversary uses lab equipment, purpose-built interposers, malicious Extension Devices, etc. to examine data intended to be confidential, modify TLP contents, & reorder and/or delete TLPs. TLP traffic can be secured as it transits Switches, extending the security model to address threats from reprogramming Switch routing mechanisms or using “malicious” Switches. Compared to the Member Review copy, and consistent with the “NOTICE TO REVIEWERS” in that copy, this final revision contains significant revisions to the key management protocol in order to align it closely with the DMTF’s Secured Messages using SPDM Specification, which was not available at the time the Member Review copy was prepared. Additionally, the final copy includes significant improvements in protection against Adversary-in-the-Middle attacks, and, consistent with member feedback received in response to the query regarding key size for AES-GCM applied to IDE TLPs, supports only the 256b key size. show less
最佳答案
查看完整内容
Here you are.
发表于 2022-4-2 22:41:38 | 显示全部楼层
Here you are.
ECN - Integrity and Data Encryption - 19 Nov 2020a.pdf
1.61 MB, 下载次数: 31 , 下载积分: 资产 -2 信元, 下载支出 2 信元
RC-NCB -- ECN - Integrity and Data Encryption Rev A - 2021-10-19.pdf
1.47 MB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
RC-CB -- ECN - Integrity and Data Encryption Rev A - 2021-10-19.pdf
1.52 MB, 下载次数: 35 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2022-4-3 08:54:42 来自手机 | 显示全部楼层
求助
 楼主| 发表于 2022-4-3 14:10:01 | 显示全部楼层
求助
 楼主| 发表于 2022-4-4 15:42:56 | 显示全部楼层
niuniu4 发表于 2022-4-2 22:41
Here you are.
多谢
发表于 2023-6-13 08:17:12 | 显示全部楼层
Here you are.
Thx a lot
发表于 2024-11-4 13:57:39 | 显示全部楼层
Here you are.
感谢你的分享。
发表于 2024-11-26 17:41:31 | 显示全部楼层
非常感谢~~~~~~~~~~~~~
发表于 2025-1-21 16:15:16 | 显示全部楼层
Thanks A Lot
GMT+8, 2025-9-13 04:20 , Processed in 1.058931 second(s), 5 queries , Gzip On, Redis On.
