楼主: ald_syn_cad
New Mentor Keygen - EFA 13.10.40.0 - 2021 + Help
发表于 2022-4-1 21:08:00 | 显示全部楼层
谢谢分享
发表于 2022-4-3 01:30:01 | 显示全部楼层
谢谢分享
发表于 2022-4-4 11:06:02 | 显示全部楼层
谢谢分享
发表于 2022-4-4 11:12:08 | 显示全部楼层
thanks
发表于 2022-4-6 11:14:36 | 显示全部楼层
非常感谢
发表于 2022-4-10 13:00:18 | 显示全部楼层
一直报这个错,楼主知道是什么原因吗?
 楼主| 发表于 2022-4-10 14:11:16 | 显示全部楼层
whuazhuo 发表于 2022-4-10 13:00
一直报这个错,楼主知道是什么原因吗?
If you want to re-do the making license, just go to the path it says (in your computer it is: C:\Users\whuaz\AppData\Local\Temp\LICENSE.TMP) and delete it (if exists) and then run the below procedures.
Patching and license generation example using the keygen:
1- Open a CMD window as administrator and go to the folder containing the "MentorKG.exe".
2- Run the below command inside CMD (just a sample):
MentorKG -patch c:\MentorGraphics -pkg c:\MentorGraphics\..\mgc.pkginfo
This command has two parts. First it patches all the required dll files inside c:\MentorGraphics folder (You can specify other folders where your intended product want to be patched). Second it searches the license features inside the mgc.pkginfo file (you need to specify the full path for this file).
In the end, a license file is created in your temp folder (C:\Users\whuaz\AppData\Local\Temp\LICENSE.TMP) and also is opened in a notepad. If it doesn't open inside a notepad, just go to the path (C:\Users\whuaz\AppData\Local\Temp\LICENSE.TMP) and copy the LICENSE.TMP to somewhere and rename it to for example LICENSE.DAT, then specify an environment variable pointing to that license.
发表于 2022-4-10 16:05:52 | 显示全部楼层
ald_syn_cad 发表于 2022-4-10 14:11
If you want to re-do the making license, just go to the path it says (in your computer it is: C:% ...
What if there're no packages installed on MS Windows? Just want to generate license for use on Linux.
 楼主| 发表于 2022-4-10 16:41:24 | 显示全部楼层
nibaix 发表于 2022-4-10 16:05
What if there're no packages installed on MS Windows? Just want to generate license for use on Lin ...
Install this on your Linux:
https://dl.winehq.org/wine/source/7.0/wine-7.0.tar.xz
Guide:
How to Install and Use Wine to Run Windows Applications on Linux
https://www.linux.com/training-tutorials/how-install-and-use-wine-run-windows-applications-linux/
Then check out if MentorKG works on your Linux as Windows then report back.
回复 支持 1 反对 1
发表于 2022-4-10 16:50:13 | 显示全部楼层
Appreciate it and will try.
GMT+8, 2025-12-21 16:08 , Processed in 0.027749 second(s), 4 queries , Gzip On, Redis On.
