楼主: ald_syn_cad
New Mentor Keygen - EFA 13.10.40.0 - 2021 + Help
发表于 2022-4-11 01:39:17 | 显示全部楼层
ald_syn_cad 发表于 2022-4-10 14:11
If you want to re-do the making license, just go to the path it says (in your computer it is: C:% ...
在linux下通过wine运行MentorKG.exe,报错还是这个Cannot overwrite 。也查看了C:\users\xxxx\Temp\文件夹,并没有LICENSE.TMP文件存在。
看您之前发的截图,应该也是存在这个问题的,就是通过删除LICENSE.TMP解决的吗?
还请您指点一下!感谢~~
 楼主| 发表于 2022-4-11 04:47:52 | 显示全部楼层
whuazhuo 发表于 2022-4-11 01:39
在linux下通过wine运行MentorKG.exe,报错还是这个Cannot overwrite 。也查看了C:%users\xxxx\Temp\文件夹 ...
On Windows (only for making license not patching the required files):
1- First create a new folder somewhere. For example on the drive C. Name it anything. Notice that the folder's name must not have Space between its characters, otherwise it won't work. For example name it Butter.
2- Search for "mgc.pkginfo" files inside your installed mentor product's folder. After finding them, copy one of them to the Butter Folder.
3- Copy "MentorKG.exe" to the Butter folder too.
4- Open a CMD window and go to the folder Butter and Run:
MentorKG -patch C:\Butter
(This command searches the license features inside "mgc.pkginfo" file in the Butter folder and makes a license file in the notepad.)
发表于 2022-4-11 16:32:02 | 显示全部楼层
1- First create a new folde ...
貌似还是没能解决这个问题,我再琢磨一下吧。
发表于 2022-4-22 23:09:33 | 显示全部楼层
非常感谢楼主分享
回复 支持 0 反对 1
发表于 2022-4-23 01:52:41 | 显示全部楼层
OK>Thanks a lot
发表于 2022-4-23 09:23:20 | 显示全部楼层
thanks
发表于 2022-5-8 13:26:29 | 显示全部楼层
谢谢分享!
发表于 2022-5-8 14:13:44 | 显示全部楼层
感谢分享
发表于 2022-5-9 11:07:32 | 显示全部楼层
新版有效!!!!
发表于 2022-5-27 00:34:03 | 显示全部楼层
试试看
GMT+8, 2025-12-9 01:26 , Processed in 0.019636 second(s), 4 queries , Gzip On, Redis On.
