查看: 2246|回复: 2
[求助] 菜鸟请教问题
发表于 2022-3-21 15:50:50 | 显示全部楼层 |阅读模式
刚入门学习画版图,试着画了一个反相器的,但是lvs出现问题,版图里的所有东西都跟source对不上不知道怎么解决,求大神指导。下面是报错
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of ports (see below).
  Error:    Connectivity errors.
LAYOUT CELL NAME:         drc_lvs_test
SOURCE CELL NAME:         drc_lvs_test
NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              0         4    *
Nets:               4         4
Instances:          2         2         M (4 pins)
Total Inst:         2         2
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               0          0            0            4
   Nets:                0          0            4            4
   Instances:           0          0            1            1    M(mn5)
                        0          0            1            1    M(mp5)
   Total Inst:          0          0            2            2
o Voltage Names Matched by Wildcard:
   Power Names from Source:
                 VDD
   Ground Names from Source:
                 GND
发表于 2022-3-21 16:04:37 | 显示全部楼层
一个port都没打啊
发表于 2022-3-21 16:08:51 | 显示全部楼层
同上
GMT+8, 2025-12-23 22:31 , Processed in 0.016277 second(s), 5 queries , Gzip On, Redis On.
