查看: 3632|回复: 6
[求助] super source follower 是怎么反馈的
发表于 2022-3-5 20:36:00 | 显示全部楼层 |阅读模式
悬赏15资产已解决
Figure 2 shows a modified architecture of source follower knownas Super Source Follower [3, 4]. A common source amplifier is connected across the common drain stage. Whencurrent through M1 increases, the gate voltage of M2 also increases which in turn reduces Vout since M2 is in commonsource configuration. When Vout is reduced, the voltage difference between gate and source of M1 decreases thereby reducing the the current though M1. This confirms the negative feedback action.
为什么M1的电流增大了,M2的栅极电压就会增大呢?为什么就会使Vout下降呢?
最佳答案
查看完整内容
上拉的电流变大了自然会把该节点的电压往上拉啊,M2的栅极电压就会上升,M2的栅极上升了,下拉的电流变大了 自然就把Vout拉低了啊
发表于 2022-3-5 20:36:01 | 显示全部楼层
发表于 2022-3-6 10:54:44 | 显示全部楼层
因为M4的Gate是固定偏置,M1电流增大必然M4的Drain增大,所以Vout就减小了
发表于 2022-3-6 14:16:12 | 显示全部楼层
 楼主| 发表于 2022-3-6 14:49:02 | 显示全部楼层
但是为什么M2的栅极电压增大了就会使VOUT减小呢?
 楼主| 发表于 2022-3-6 21:23:44 | 显示全部楼层
11111
发表于 2022-3-7 09:16:12 | 显示全部楼层
如果VOUT降低,VSGM1降低,IDSM1减小,又因为IDSM3=IDSM1+IOUT(IDSM2),所以IOUT(IDSM2)增加,VGM2增加。
GMT+8, 2025-9-12 18:03 , Processed in 0.016254 second(s), 5 queries , Gzip On, Redis On.
