查看: 3019|回复: 2
[求助] 请问關於 Design Compiler 综合的错误讯息
发表于 2022-2-25 01:34:37 | 显示全部楼层 |阅读模式
昨天第一次跑Design Compiler,内容是DC教程的lab1,综合时出现以下错误讯息:
dc_shell-topo> compile_ultra
Information: Performing power optimization. (PWR-850)
Alib files are up-to-date.
Error: Layer METAL does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Layer METAL2 does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Layer METAL3 does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Layer METAL4 does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Layer METAL5 does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Layer METAL6 does not have preferred routing direction defined, neither in the design(CEL) nor in the library. (PSYN-486)
Error: Routing layers sanity check failed. (OPT-1430)
Warning: Some checks cannot be performed because of previous errors. (DCT-006)
0
该设定的应该都有设定正确,实在找不到问题。
请问各位业界前辈问题点是?或者是告诉我查的方向,谢谢。
发表于 2022-2-25 09:52:10 | 显示全部楼层
没有对layer设置绕线方向,需要定义
set_attribute [get_layer ] routing_direction h/v
这个东西在innovus中是直接读取lef,但是s家的工具是需要我们去设置。
发表于 2022-10-23 16:09:25 | 显示全部楼层
set_preferred_routing_direction -layer METAL1 -direction H
set_preferred_routing_direction -layer METAL2 -direction V
set_preferred_routing_direction -layer METAL3 -direction H
set_preferred_routing_direction -layer METAL4 -direction V
set_preferred_routing_direction -layer METAL5 -direction H
set_preferred_routing_direction -layer METAL6 -direction V
回复 支持 0 反对 1
GMT+8, 2025-9-19 12:02 , Processed in 0.011865 second(s), 4 queries , Gzip On, Redis On.
