查看: 22625|回复: 81
[资料] New Crack MentorGraphics HDS_2021、Precision 2020、Modelsim 2021、QuestaSim 2021
发表于 2022-1-31 04:50:43 | 显示全部楼层 |阅读模式
New Crack MentorGraphics HDS_2021、Precision 2020、Modelsim 2021、QuestaSim 2021、
(How to patch MentorGraphics HDS_2021, Precision 2020, Modelsim 2021, QuestaSim 2021)
1. Install Mentor all products in directory "C:\MentorGraphics\"
   - HDS_2021
   - Precision 2020
   - Modelsim 2021
   - QuestaSim 2021
1. Do clear flag "r" - "read only" for all files in "C:\MentorGraphics\" directory.
2. Create directory "C:\MentorGraphics\license_files\"
3. Copy files from directory "Mentor_Crack.2021" to directory "C:\temp"
  - MentorKG.exe
  - Mentor_PatchTool_V1.0c.exe
  - ReadMe.txt
  - 1.generate_license.bat
  - 2.Mentor_Patch.bat
5. Run from "C:\temp" (to generate license on installed products):
   "1.generate_license.bat"
      As a result : creat license file "LICENSE.TXT" in directory "C:\MentorGraphics\license_files\"
6. Set the MGLS_LICENSE_FILE environment variable.
   MGLS_LICENSE_FILE = C:\MentorGraphics\license_files\LICENSE.TXT
7. Run from "C:\temp" (to patch your software):
   "2.Mentor_Patch.bat"
      As a result : patch all installed products - HDS_2021, Precision 2020, Modelsim 2021, QuestaSim 2021.
8. Enjoy!
1. 在目录“C:\MentorGraphics\”中安装 Mentor 所有产品
   - HDS_2021
   - 精密 2020
   - 模型模拟 2021
   - QuestaSim 2021
1. 清除“C:\MentorGraphics\”目录中所有文件的标志“r”-“只读”。
2. 创建目录“C:\MentorGraphics\license_files\”
3. 从目录“Mentor_Crack.
  2021" 到目录 "C:\temp"
  - MentorKG.exe
  - 自述文件.txt
5. 从“C:\temp”运行(在已安装的产品上生成许可证):
   “1.generate_license.bat”
    结果:在目录“C:\MentorGraphics\license_files\”中创建许可证文件“LICENSE.TXT”
6. 设置 MGLS_LICENSE_FILE 环境变量。
   MGLS_LICENSE_FILE = C:\MentorGraphics\license_files\LICENSE。文本文件
7. 从“C:\temp”运行(修补您的软件):
   “2.Mentor_Patch.bat”
   结果:修补所有已安装的产品 - HDS_2021、Precision 2020、Modelsim 2021、QuestaSim 2021。
8.享受!
1.generate_license.zip
253 Bytes, 下载次数: 522 , 下载积分: 资产 -2 信元, 下载支出 2 信元
2.Mentor_Patch.zip
238 Bytes, 下载次数: 496 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Mentor_PatchTool_V1.0c.zip
137.4 KB, 下载次数: 487 , 下载积分: 资产 -2 信元, 下载支出 2 信元
MentorKG.zip
614.26 KB, 下载次数: 511 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ReadMe.zip
659 Bytes, 下载次数: 484 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Mentor_Crack.2021.zip
753.02 KB, 下载次数: 628 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-1-31 10:50:56 | 显示全部楼层
Thanks a lot, It helps in all respect.
发表于 2022-1-31 12:38:17 | 显示全部楼层
thanks for sharing
发表于 2022-1-31 13:15:30 | 显示全部楼层
thanks
发表于 2022-1-31 13:17:34 | 显示全部楼层
for linux?
发表于 2022-1-31 14:13:22 | 显示全部楼层
发表于 2022-1-31 14:31:03 | 显示全部楼层
thanks a lot, let me have a look!
发表于 2022-1-31 17:32:01 | 显示全部楼层
tks a lot
发表于 2022-1-31 17:34:23 | 显示全部楼层
where the tools is ?
发表于 2022-1-31 18:36:02 | 显示全部楼层
thanks
GMT+8, 2025-10-27 05:33 , Processed in 0.018810 second(s), 4 queries , Gzip On, Redis On.
