查看: 2677|回复: 7
[求助] 后端create_pad_rings出错
发表于 2022-1-22 11:30:08 | 显示全部楼层 |阅读模式
后端create_pad_rings出错,版图中没有pad rings生成
icc_shell> create_pad_rings
Using [5 x 5] Fat Wire Table for M1
Using [5 x 5] Fat Wire Table for M2
Using [5 x 5] Fat Wire Table for M3
Using [5 x 5] Fat Wire Table for M4
Using [5 x 5] Fat Wire Table for M5
Using [5 x 5] Fat Wire Table for M6
Using [5 x 5] Fat Wire Table for M7
Using [3 x 3] Fat Wire Table for M8
Using [3 x 3] Fat Wire Table for M9
Using [5 x 5] Fat Wire Table for VIA1
Using [5 x 5] Fat Wire Table for VIA2
Using [5 x 5] Fat Wire Table for VIA3
Using [5 x 5] Fat Wire Table for VIA4
Using [5 x 5] Fat Wire Table for VIA5
Using [5 x 5] Fat Wire Table for VIA6
Using [3 x 3] Fat Wire Table for VIA7
Using [3 x 3] Fat Wire Table for VIA8
110 cells out of bound
Number of boundaries processed:
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M1 because of obstruction: (188.840 504.160)(190.000 505.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M2 because of obstruction: (188.840 504.160)(190.000 505.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M3 because of obstruction: (188.840 504.160)(190.000 505.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M4 because of obstruction: (188.840 504.160)(190.000 505.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M5 because of obstruction: (188.840 504.160)(190.000 505.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M6 because of obstruction: (188.840 504.160)(190.000 505.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 501.230)(190.000 504.000) M7 because of obstruction: (188.840 504.160)(190.000 505.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M1 because of obstruction: (188.840 470.000)(190.000 470.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M2 because of obstruction: (188.840 470.000)(190.000 470.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M3 because of obstruction: (188.840 470.000)(190.000 470.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M4 because of obstruction: (188.840 470.000)(190.000 470.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M5 because of obstruction: (188.840 470.000)(190.000 470.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M6 because of obstruction: (188.840 470.000)(190.000 470.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 471.000)(190.000 473.770) M7 because of obstruction: (188.840 470.000)(190.000 470.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M1 because of obstruction: (188.840 329.160)(190.000 330.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M2 because of obstruction: (188.840 329.160)(190.000 330.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M3 because of obstruction: (188.840 329.160)(190.000 330.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M4 because of obstruction: (188.840 329.160)(190.000 330.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M5 because of obstruction: (188.840 329.160)(190.000 330.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M6 because of obstruction: (188.840 329.160)(190.000 330.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 326.230)(190.000 329.000) M7 because of obstruction: (188.840 329.160)(190.000 330.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M1 because of obstruction: (188.840 295.000)(190.000 295.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M2 because of obstruction: (188.840 295.000)(190.000 295.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M3 because of obstruction: (188.840 295.000)(190.000 295.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M4 because of obstruction: (188.840 295.000)(190.000 295.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M5 because of obstruction: (188.840 295.000)(190.000 295.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M6 because of obstruction: (188.840 295.000)(190.000 295.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 296.000)(190.000 298.770) M7 because of obstruction: (188.840 295.000)(190.000 295.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M1 because of obstruction: (188.840 294.160)(190.000 295.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M2 because of obstruction: (188.840 294.160)(190.000 295.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M3 because of obstruction: (188.840 294.160)(190.000 295.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M4 because of obstruction: (188.840 294.160)(190.000 295.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M5 because of obstruction: (188.840 294.160)(190.000 295.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M6 because of obstruction: (188.840 294.160)(190.000 295.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 291.230)(190.000 294.000) M7 because of obstruction: (188.840 294.160)(190.000 295.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M1 because of obstruction: (188.840 260.000)(190.000 260.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M2 because of obstruction: (188.840 260.000)(190.000 260.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M3 because of obstruction: (188.840 260.000)(190.000 260.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M4 because of obstruction: (188.840 260.000)(190.000 260.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M5 because of obstruction: (188.840 260.000)(190.000 260.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M6 because of obstruction: (188.840 260.000)(190.000 260.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 261.000)(190.000 263.770) M7 because of obstruction: (188.840 260.000)(190.000 260.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M1 because of obstruction: (188.840 259.160)(190.000 260.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M2 because of obstruction: (188.840 259.160)(190.000 260.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M3 because of obstruction: (188.840 259.160)(190.000 260.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M4 because of obstruction: (188.840 259.160)(190.000 260.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M5 because of obstruction: (188.840 259.160)(190.000 260.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M6 because of obstruction: (188.840 259.160)(190.000 260.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 256.230)(190.000 259.000) M7 because of obstruction: (188.840 259.160)(190.000 260.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M1 because of obstruction: (188.840 225.000)(190.000 225.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M2 because of obstruction: (188.840 225.000)(190.000 225.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M3 because of obstruction: (188.840 225.000)(190.000 225.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M4 because of obstruction: (188.840 225.000)(190.000 225.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M5 because of obstruction: (188.840 225.000)(190.000 225.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M6 because of obstruction: (188.840 225.000)(190.000 225.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 226.000)(190.000 228.770) M7 because of obstruction: (188.840 225.000)(190.000 225.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M1 because of obstruction: (188.840 224.160)(190.000 225.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M2 because of obstruction: (188.840 224.160)(190.000 225.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M3 because of obstruction: (188.840 224.160)(190.000 225.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M4 because of obstruction: (188.840 224.160)(190.000 225.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M5 because of obstruction: (188.840 224.160)(190.000 225.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M6 because of obstruction: (188.840 224.160)(190.000 225.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 221.230)(190.000 224.000) M7 because of obstruction: (188.840 224.160)(190.000 225.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M1 because of obstruction: (188.840 190.000)(190.000 190.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M2 because of obstruction: (188.840 190.000)(190.000 190.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M3 because of obstruction: (188.840 190.000)(190.000 190.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M4 because of obstruction: (188.840 190.000)(190.000 190.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M5 because of obstruction: (188.840 190.000)(190.000 190.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M6 because of obstruction: (188.840 190.000)(190.000 190.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 191.000)(190.000 193.770) M7 because of obstruction: (188.840 190.000)(190.000 190.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M1 because of obstruction: (188.840 609.160)(190.000 610.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M2 because of obstruction: (188.840 609.160)(190.000 610.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M3 because of obstruction: (188.840 609.160)(190.000 610.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M4 because of obstruction: (188.840 609.160)(190.000 610.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M5 because of obstruction: (188.840 609.160)(190.000 610.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M6 because of obstruction: (188.840 609.160)(190.000 610.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 606.230)(190.000 609.000) M7 because of obstruction: (188.840 609.160)(190.000 610.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M1 because of obstruction: (188.840 575.000)(190.000 575.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M2 because of obstruction: (188.840 575.000)(190.000 575.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M3 because of obstruction: (188.840 575.000)(190.000 575.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M4 because of obstruction: (188.840 575.000)(190.000 575.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M5 because of obstruction: (188.840 575.000)(190.000 575.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M6 because of obstruction: (188.840 575.000)(190.000 575.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 576.000)(190.000 578.770) M7 because of obstruction: (188.840 575.000)(190.000 575.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M1 because of obstruction: (188.840 574.160)(190.000 575.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M2 because of obstruction: (188.840 574.160)(190.000 575.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M3 because of obstruction: (188.840 574.160)(190.000 575.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M4 because of obstruction: (188.840 574.160)(190.000 575.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M5 because of obstruction: (188.840 574.160)(190.000 575.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M6 because of obstruction: (188.840 574.160)(190.000 575.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 571.230)(190.000 574.000) M7 because of obstruction: (188.840 574.160)(190.000 575.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M1 because of obstruction: (188.840 540.000)(190.000 540.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M2 because of obstruction: (188.840 540.000)(190.000 540.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M3 because of obstruction: (188.840 540.000)(190.000 540.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M4 because of obstruction: (188.840 540.000)(190.000 540.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M5 because of obstruction: (188.840 540.000)(190.000 540.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M6 because of obstruction: (188.840 540.000)(190.000 540.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 541.000)(190.000 543.770) M7 because of obstruction: (188.840 540.000)(190.000 540.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M1 because of obstruction: (188.840 539.160)(190.000 540.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M2 because of obstruction: (188.840 539.160)(190.000 540.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M3 because of obstruction: (188.840 539.160)(190.000 540.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M4 because of obstruction: (188.840 539.160)(190.000 540.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M5 because of obstruction: (188.840 539.160)(190.000 540.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M6 because of obstruction: (188.840 539.160)(190.000 540.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 536.230)(190.000 539.000) M7 because of obstruction: (188.840 539.160)(190.000 540.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M1 because of obstruction: (188.840 505.000)(190.000 505.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M2 because of obstruction: (188.840 505.000)(190.000 505.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M3 because of obstruction: (188.840 505.000)(190.000 505.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M4 because of obstruction: (188.840 505.000)(190.000 505.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M5 because of obstruction: (188.840 505.000)(190.000 505.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M6 because of obstruction: (188.840 505.000)(190.000 505.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (189.000 506.000)(190.000 508.770) M7 because of obstruction: (188.840 505.000)(190.000 505.840) M7 (PGRT-059)
[1]
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M1 because of obstruction: (259.160 610.000)(260.000 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M2 because of obstruction: (259.160 610.000)(260.000 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M3 because of obstruction: (259.160 610.000)(260.000 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M4 because of obstruction: (259.160 610.000)(260.000 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M5 because of obstruction: (259.160 610.000)(260.000 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M6 because of obstruction: (259.160 610.000)(260.000 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (256.230 610.000)(259.000 611.000) M7 because of obstruction: (259.160 610.000)(260.000 611.160) M7 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M1 because of obstruction: (225.000 610.000)(225.840 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M2 because of obstruction: (225.000 610.000)(225.840 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M3 because of obstruction: (225.000 610.000)(225.840 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M4 because of obstruction: (225.000 610.000)(225.840 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M5 because of obstruction: (225.000 610.000)(225.840 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M6 because of obstruction: (225.000 610.000)(225.840 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (226.000 610.000)(228.770 611.000) M7 because of obstruction: (225.000 610.000)(225.840 611.160) M7 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M1 because of obstruction: (224.160 610.000)(225.000 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M2 because of obstruction: (224.160 610.000)(225.000 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M3 because of obstruction: (224.160 610.000)(225.000 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M4 because of obstruction: (224.160 610.000)(225.000 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M5 because of obstruction: (224.160 610.000)(225.000 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M6 because of obstruction: (224.160 610.000)(225.000 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (221.230 610.000)(224.000 611.000) M7 because of obstruction: (224.160 610.000)(225.000 611.160) M7 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M1 because of obstruction: (190.000 610.000)(190.840 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M2 because of obstruction: (190.000 610.000)(190.840 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M3 because of obstruction: (190.000 610.000)(190.840 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M4 because of obstruction: (190.000 610.000)(190.840 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M5 because of obstruction: (190.000 610.000)(190.840 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M6 because of obstruction: (190.000 610.000)(190.840 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (191.000 610.000)(193.770 611.000) M7 because of obstruction: (190.000 610.000)(190.840 611.160) M7 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M1 because of obstruction: (434.160 610.000)(435.000 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M2 because of obstruction: (434.160 610.000)(435.000 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M3 because of obstruction: (434.160 610.000)(435.000 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M4 because of obstruction: (434.160 610.000)(435.000 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M5 because of obstruction: (434.160 610.000)(435.000 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M6 because of obstruction: (434.160 610.000)(435.000 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (431.230 610.000)(434.000 611.000) M7 because of obstruction: (434.160 610.000)(435.000 611.160) M7 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M1 because of obstruction: (469.160 610.000)(470.000 611.160) M1 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M2 because of obstruction: (469.160 610.000)(470.000 611.160) M2 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M3 because of obstruction: (469.160 610.000)(470.000 611.160) M3 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M4 because of obstruction: (469.160 610.000)(470.000 611.160) M4 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M5 because of obstruction: (469.160 610.000)(470.000 611.160) M5 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M6 because of obstruction: (469.160 610.000)(470.000 611.160) M6 (PGRT-059)
Warning: Cannot connect pad pin (466.230 610.000)(469.000 611.000) M7 because of obstruction: (469.160 610.000)(470.000 611.160) M7 (PGRT-059)
[2]
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M1 because of obstruction: (470.000 225.000)(471.160 225.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M2 because of obstruction: (470.000 225.000)(471.160 225.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M3 because of obstruction: (470.000 225.000)(471.160 225.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M4 because of obstruction: (470.000 225.000)(471.160 225.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M5 because of obstruction: (470.000 225.000)(471.160 225.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M6 because of obstruction: (470.000 225.000)(471.160 225.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 226.000)(471.000 228.770) M7 because of obstruction: (470.000 225.000)(471.160 225.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M1 because of obstruction: (470.000 259.160)(471.160 260.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M2 because of obstruction: (470.000 259.160)(471.160 260.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M3 because of obstruction: (470.000 259.160)(471.160 260.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M4 because of obstruction: (470.000 259.160)(471.160 260.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M5 because of obstruction: (470.000 259.160)(471.160 260.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M6 because of obstruction: (470.000 259.160)(471.160 260.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 256.230)(471.000 259.000) M7 because of obstruction: (470.000 259.160)(471.160 260.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M1 because of obstruction: (470.000 190.000)(471.160 190.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M2 because of obstruction: (470.000 190.000)(471.160 190.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M3 because of obstruction: (470.000 190.000)(471.160 190.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M4 because of obstruction: (470.000 190.000)(471.160 190.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M5 because of obstruction: (470.000 190.000)(471.160 190.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M6 because of obstruction: (470.000 190.000)(471.160 190.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 191.000)(471.000 193.770) M7 because of obstruction: (470.000 190.000)(471.160 190.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M1 because of obstruction: (470.000 224.160)(471.160 225.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M2 because of obstruction: (470.000 224.160)(471.160 225.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M3 because of obstruction: (470.000 224.160)(471.160 225.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M4 because of obstruction: (470.000 224.160)(471.160 225.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M5 because of obstruction: (470.000 224.160)(471.160 225.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M6 because of obstruction: (470.000 224.160)(471.160 225.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 221.230)(471.000 224.000) M7 because of obstruction: (470.000 224.160)(471.160 225.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M1 because of obstruction: (470.000 470.000)(471.160 470.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M2 because of obstruction: (470.000 470.000)(471.160 470.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M3 because of obstruction: (470.000 470.000)(471.160 470.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M4 because of obstruction: (470.000 470.000)(471.160 470.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M5 because of obstruction: (470.000 470.000)(471.160 470.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M6 because of obstruction: (470.000 470.000)(471.160 470.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 471.000)(471.000 473.770) M7 because of obstruction: (470.000 470.000)(471.160 470.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M1 because of obstruction: (470.000 295.000)(471.160 295.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M2 because of obstruction: (470.000 295.000)(471.160 295.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M3 because of obstruction: (470.000 295.000)(471.160 295.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M4 because of obstruction: (470.000 295.000)(471.160 295.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M5 because of obstruction: (470.000 295.000)(471.160 295.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M6 because of obstruction: (470.000 295.000)(471.160 295.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 296.000)(471.000 298.770) M7 because of obstruction: (470.000 295.000)(471.160 295.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M1 because of obstruction: (470.000 260.000)(471.160 260.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M2 because of obstruction: (470.000 260.000)(471.160 260.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M3 because of obstruction: (470.000 260.000)(471.160 260.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M4 because of obstruction: (470.000 260.000)(471.160 260.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M5 because of obstruction: (470.000 260.000)(471.160 260.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M6 because of obstruction: (470.000 260.000)(471.160 260.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 261.000)(471.000 263.770) M7 because of obstruction: (470.000 260.000)(471.160 260.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M1 because of obstruction: (470.000 294.160)(471.160 295.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M2 because of obstruction: (470.000 294.160)(471.160 295.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M3 because of obstruction: (470.000 294.160)(471.160 295.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M4 because of obstruction: (470.000 294.160)(471.160 295.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M5 because of obstruction: (470.000 294.160)(471.160 295.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M6 because of obstruction: (470.000 294.160)(471.160 295.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 291.230)(471.000 294.000) M7 because of obstruction: (470.000 294.160)(471.160 295.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M1 because of obstruction: (470.000 575.000)(471.160 575.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M2 because of obstruction: (470.000 575.000)(471.160 575.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M3 because of obstruction: (470.000 575.000)(471.160 575.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M4 because of obstruction: (470.000 575.000)(471.160 575.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M5 because of obstruction: (470.000 575.000)(471.160 575.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M6 because of obstruction: (470.000 575.000)(471.160 575.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 576.000)(471.000 578.770) M7 because of obstruction: (470.000 575.000)(471.160 575.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M1 because of obstruction: (470.000 540.000)(471.160 540.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M2 because of obstruction: (470.000 540.000)(471.160 540.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M3 because of obstruction: (470.000 540.000)(471.160 540.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M4 because of obstruction: (470.000 540.000)(471.160 540.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M5 because of obstruction: (470.000 540.000)(471.160 540.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M6 because of obstruction: (470.000 540.000)(471.160 540.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 541.000)(471.000 543.770) M7 because of obstruction: (470.000 540.000)(471.160 540.840) M7 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M1 because of obstruction: (470.000 505.000)(471.160 505.840) M1 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M2 because of obstruction: (470.000 505.000)(471.160 505.840) M2 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M3 because of obstruction: (470.000 505.000)(471.160 505.840) M3 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M4 because of obstruction: (470.000 505.000)(471.160 505.840) M4 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M5 because of obstruction: (470.000 505.000)(471.160 505.840) M5 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M6 because of obstruction: (470.000 505.000)(471.160 505.840) M6 (PGRT-059)
Warning: Cannot connect pad pin (470.000 506.000)(471.000 508.770) M7 because of obstruction: (470.000 505.000)(471.160 505.840) M7 (PGRT-059)
[3]
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M1 because of obstruction: (271.665 188.840)(272.505 190.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M2 because of obstruction: (271.665 188.840)(272.505 190.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M3 because of obstruction: (271.665 188.840)(272.505 190.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M4 because of obstruction: (271.665 188.840)(272.505 190.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M5 because of obstruction: (271.665 188.840)(272.505 190.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M6 because of obstruction: (271.665 188.840)(272.505 190.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (272.665 189.000)(275.435 190.000) M7 because of obstruction: (271.665 188.840)(272.505 190.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M1 because of obstruction: (230.830 188.840)(231.670 190.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M2 because of obstruction: (230.830 188.840)(231.670 190.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M3 because of obstruction: (230.830 188.840)(231.670 190.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M4 because of obstruction: (230.830 188.840)(231.670 190.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M5 because of obstruction: (230.830 188.840)(231.670 190.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M6 because of obstruction: (230.830 188.840)(231.670 190.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (231.830 189.000)(234.600 190.000) M7 because of obstruction: (230.830 188.840)(231.670 190.000) M7 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M1 because of obstruction: (190.000 188.840)(190.840 190.000) M1 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M2 because of obstruction: (190.000 188.840)(190.840 190.000) M2 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M3 because of obstruction: (190.000 188.840)(190.840 190.000) M3 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M4 because of obstruction: (190.000 188.840)(190.840 190.000) M4 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M5 because of obstruction: (190.000 188.840)(190.840 190.000) M5 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M6 because of obstruction: (190.000 188.840)(190.840 190.000) M6 (PGRT-059)
Warning: Cannot connect pad pin (191.000 189.000)(193.770 190.000) M7 because of obstruction: (190.000 188.840)(190.840 190.000) M7 (PGRT-059)
[4]
[done]
发表于 2024-4-30 15:06:40 | 显示全部楼层
同样的问题,请问大哥你当时解决了么
 楼主| 发表于 2024-4-30 19:37:03 | 显示全部楼层
ic小白22 发表于 2024-4-30 15:06
同样的问题,请问大哥你当时解决了么
没有,后来就没搞了。。。
发表于 2024-5-11 12:32:19 | 显示全部楼层
同样的问题,请问大哥你当时解决了么
大哥你解决没 我也遇到了这个问题
发表于 2024-5-11 16:20:43 | 显示全部楼层
huangbobo 发表于 2024-5-11 12:32
大哥你解决没 我也遇到了这个问题
我发现不影响后面的步骤,就不理它了哈哈哈,毕竟只是一个warning
发表于 2024-5-11 16:22:12 | 显示全部楼层
大哥你解决没 我也遇到了这个问题
朋友你也是刚学ic后端么,缺一个学习搭子,一起加个联系方式平时交流?
发表于 2024-5-11 20:31:13 | 显示全部楼层
好! 我也刚学 我wx hb1650391632
发表于 2024-5-13 11:14:23 | 显示全部楼层
已加
GMT+8, 2025-12-14 01:12 , Processed in 0.055675 second(s), 4 queries , Gzip On, Redis On.
