查看: 2577|回复: 6
[求助] 求大神帮忙分析比较器功能
发表于 2022-1-20 16:38:02 | 显示全部楼层 |阅读模式
小白一个,这是ISSCC上一个比较器,但是不知道这个是怎么工作的,有没有大神帮忙解释一下,另外还想知道这两个栅极上的电容和那两个开关有什么作用,望不吝赐教
发表于 2022-1-20 17:25:13 | 显示全部楼层
开关和电容应该是用来补偿offset的。论文名称有吗?
发表于 2022-1-20 21:46:34 | 显示全部楼层
Picture is not clear
 楼主| 发表于 2022-1-21 09:33:12 | 显示全部楼层
A 1.1μm-Pitch 13.5Mpixel 3D-Stacked CMOS Image Sensor Featuring 230fps Full-High Definition and 514fps
名称是这个,另外还想问一下,这个开关时序以及电容大小有什么考究吗
 楼主| 发表于 2022-1-21 09:45:28 | 显示全部楼层
image.png 这个可能会好点
发表于 2022-1-21 23:34:37 | 显示全部楼层
This comparator is used in the sar adc, uh?The switches and the capacitors uesd here are to sample the input signal and cancell the offset of the comparator and compare the input signal and ref signal. The switch timings need non-overlap. The vaule of the capacitor mainly depends on noise requirments of the sar adc. For further resarch, you can refer to chapter swithed capacitor of Razavi's book.
 楼主| 发表于 2022-1-22 10:14:53 | 显示全部楼层
任性 发表于 2022-1-21 23:34
This comparator is used in the sar adc, uh?The switches and the capacitors uesd here are to sample  ...
谢谢,我再去研究研究
GMT+8, 2025-12-30 11:09 , Processed in 0.021170 second(s), 4 queries , Gzip On, Redis On.
