查看: 2530|回复: 0
求助:EXT191安装后报错
发表于 2022-1-3 21:35:40 | 显示全部楼层 |阅读模式
悬赏500资产未解决
各位大佬求助:EXT191安装后报错
All device symbols for the extracted view are present.
INFO (LBRCXU-114): Finished /opt/eda/cadence/IC618_ISR13/bin/qrcToDfII
INFO (LBRCXM-642): Constructing the RCX run script
Forking: agdsPrep -V -rundir /home/project/query_output -outdir /tmp/qrc_253692/aaaaa -sch -df2 -e /home/project/csc7333/ic61/smic/smic18bcd/smic18bcd.layermap:aaaaa.alm,aaaaa.ilf -pl aaaaa.ports -mcell /tmp/qrc_253692/aaaaa/aaaaa.mcl -d aaaaa.devtab -l /home/project/csc7333/ic61/smic/data/rulefiles/TYPICAL/lvsfile -w /tmp/qrc_253692/aaaaa/aaaaa.hcl:/tmp/qrc_253692/aaaaa/aaaaa.hcl,/home/project/csc7333/ic61/smic/data/TD-BC18-XQ-2074v0/SMIC_CCIQRC_018V3EBCD_18506090120160200240300350400_1P4M_3Ia_1MTT2_2ndMIM10_V1.0_REV4_0/rulefiles/TYPICAL/preserveCellList.txt:/tmp/qrc_253692/aaaaa/aaaaa.dcl -i aaaaa.ixf,aaaaa.lph,aaaaa.sph:aaaaa.gdx -n aaaaa.nxf,aaaaa.stl:aaaaa.gnx -s aaaaa_pin_xy.spi:aaaaa.xcn,hccidtmfile
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  Quantus terminated abnormally  *****
GMT+8, 2025-12-23 07:00 , Processed in 0.012692 second(s), 4 queries , Gzip On, Redis On.
