查看: 2597|回复: 3
[讨论] icc place出错:could not find a legal placement
发表于 2021-12-26 10:32:32 | 显示全部楼层 |阅读模式
Std cell utilization: 96.45%  (53640/(56406-790))
(Non-fixed + Fixed)
Std cell utilization: 99.64%  (53640/(56406-2570))
(Non-fixed only)
Chip area:            56406    sites, bbox (3.00 3.00 102.96 102.54) um
Std cell area:        53640    sites, (non-fixed:53640  fixed:0)
                      6015     cells, (non-fixed:6015   fixed:0)
Macro cell area:      0        sites
                      0        cells
Placement blockages:  790      sites, (excluding fixed std cells)
                      2570     sites, (include fixed std cells & chimney area)
                      790      sites, (complete p/g net blockages)
Routing blockages:    0        sites, (partial p/g net blockages)
                      0        sites, (routing blockages and signal pre-route)
Lib cell count:       191
Avg. std cell width:  1.76 um
Site array:           unit     (width: 0.14 um, height: 1.26 um, rows: 79)
Physical DB scale:    1000 db_unit = 1 um
  Report : pnet options
  Design : booth2_multi_32
  Version: R-2020.09-SP5
  Date   : Sun Dec 26 10:23:53 2021
Layer      Blockage   Min_width   Min_height   Via_additive     Density
M1         none          ---         ---       via additive      ---
M2         none          ---         ---       via additive      ---
M3         none          ---         ---       via additive      ---
M4         none          ---         ---       via additive      ---
M5         none          ---         ---       via additive      ---
M6         complete    0.00        0.00        via additive      ---
M7         none          ---         ---       via additive      ---
AP         none          ---         ---       via additive      ---
Legalizing 6013 illegal cells...
Starting legalizer.
Warning: Density is 99.6% (PSYN-1010)
Initial legalization:  100% (0 sec)
Initial legalization:  10% 20% 30% 40% 50% 60% 70% 80% 90% 100% (0 sec)
Error: Could not find a legal placement.
Legalization complete (0 total sec)
Top 5 lib cells with lowest legal rate:
Error: A legal placement could not be found. (PSYN-044)
 楼主| 发表于 2021-12-26 10:42:37 | 显示全部楼层
Error: An error has occurred in the execution of the detailed placer. (PSYN-060)
Error: psynopt has abnormally terminated.  (OPT-100)
发表于 2021-12-26 11:14:39 | 显示全部楼层
面积太小?
 楼主| 发表于 2021-12-26 12:51:41 | 显示全部楼层
应该是面积太小的原因。我DC综出来的面积是6864.96,我把它除以0.7开根号,取100 place出错。后来我改了,除以0.6,再开根号取107,Place是过了。
GMT+8, 2025-11-30 13:13 , Processed in 0.019445 second(s), 3 queries , Gzip On, Redis On.
