查看: 2751|回复: 3
[求助] report-timing -begin_end_pair 的作用是什么
发表于 2021-12-22 14:57:42 | 显示全部楼层 |阅读模式
-begin_end_pair
发表于 2021-12-22 16:58:09 | 显示全部楼层
你说的应该是-start_end_pair吧,Reports the worst path for each startpoint-endpoint pair in the design, including all violating startpoint-endpoint pairs by default, or all startpoint-endpoint pairs with slack worse than the value specified by the -slack_lesser_than option if that option is used. The number of paths reported is limited to 2000000 unless -max_paths is used to exceed this.
发表于 2021-12-22 17:13:47 | 显示全部楼层
哪个工具的命令
发表于 2021-12-23 11:24:32 | 显示全部楼层
very nice, thank you so much.
GMT+8, 2025-12-18 18:58 , Processed in 0.017835 second(s), 4 queries , Gzip On, Redis On.
