查看: 2568|回复: 9
[求助] Please upload this paper, I need it. Design of a Low-Noise, Fast Set-up and Low-Voltage
发表于 2021-12-10 17:15:28 | 显示全部楼层 |阅读模式
Design of a Low-Noise, Fast Set-up and Low-Voltage Low-Dropout Regulator Featuring 230mA Load Current RangePublisher: IEEE
Cite This
[url=][size=1.15]PDF[/url]
[size=0.87][size=0.87]Darshil Patel
[url=]All Authors[/url]
[size=1.2em]114
Full
Text Views
  • [size=1.25]
  • [size=1.2]
  • [url=][size=1.25][/url]
[size=1em]Abstract
[size=1em]Document Sections
  • [size=0.9em][url=]I.
    Introduction
    [/url]
  • [size=0.9em][url=]II.
    Design of High Slew Rate Op-Amp
    [/url]
  • [size=0.9em][url=]III.
    Complete Ldo Regulator Design and its Analysis
    [/url]
  • [size=0.9em][url=]IV.
    Conclusion
    [/url]
[size=1em]Authors
[size=1em]Figures
[size=1em]References
[size=1em]Keywords
[size=1em]Metrics
Abstractow noise, high PSRR and fast transient low-dropout (LDO) regulators are critical for analog blocks such as ADCs, PLLs and RF SOC, etc. This paper presents design of low power, fast transient, high PSRR and high load-regulation low-dropout (LDO) regulator. The proposed LDO regulator is designed in 180nm. CMOS process and simulated in LTSpice and Cadence platform. The LDO proposed can support input voltage range up to 5V for loading currents up to 230mA. Measurements showed transient time or set-up time of less than 22μs, PSRR of ~66dB at 100kHz and >40dB at 1MHz and 0.8535mV of output voltage variation for a 0-230mA of load variation.
Published in: 2021 4th Biennial International Conference on Nascent Technologies in Engineering (ICNTE)
Date of Conference: 15-16 Jan. 2021
Date Added to IEEE Xplore: 30 July 2021
ISBN Information:
INSPEC Accession Number: 20995393
DOI: 10.1109/ICNTE51185.2021.9487577
Publisher: IEEE
 楼主| 发表于 2021-12-11 11:21:57 | 显示全部楼层
Please upload this paper. Thank you very much.
发表于 2021-12-11 15:05:47 | 显示全部楼层
Please check
Design_of_a_Low-Noise_Fast_Set-up_and_Low-Voltage_Low-Dropout_Regulator_Featurin.pdf
1.01 MB, 下载次数: 45 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2021-12-11 21:12:29 | 显示全部楼层
kankan
 楼主| 发表于 2021-12-11 22:20:24 | 显示全部楼层
发表于 2021-12-12 18:33:43 | 显示全部楼层
发表于 2021-12-12 21:14:36 | 显示全部楼层
thanks for sharing
发表于 2022-1-26 16:04:22 | 显示全部楼层
互相帮助
发表于 2022-2-28 20:14:48 | 显示全部楼层
看看。。。。。。。。。。。。。。。
发表于 2022-4-11 07:35:58 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-25 06:16 , Processed in 0.025641 second(s), 4 queries , Gzip On, Redis On.
