查看: 2693|回复: 7
[求助] 积分器输出波形问题
发表于 2021-12-3 15:34:36 | 显示全部楼层 |阅读模式
发表于 2021-12-3 15:46:36 | 显示全部楼层
你是不是哪个结点上挂了大电容?感觉是每个周期给电容充一点电,你仿真时间加长,最后应该能看到稳定的一个瞬态结果。
 楼主| 发表于 2021-12-3 16:10:39 | 显示全部楼层
wkp1992101 发表于 2021-12-3 15:46
你是不是哪个结点上挂了大电容?感觉是每个周期给电容充一点电,你仿真时间加长,最后应该能看到稳定的一个 ...
发表于 2021-12-4 11:24:04 | 显示全部楼层
Curious, is this the output voltage waveform? Why are your output common-mode voltages inconsistent
 楼主| 发表于 2021-12-5 19:49:40 | 显示全部楼层
yes,it is the output waveform. I still don't know the reason.
发表于 2021-12-6 21:35:30 | 显示全部楼层
maybe it's incorrect for the CMFB
 楼主| 发表于 2021-12-7 09:29:48 | 显示全部楼层
I have check it, my CMFB Loopgain PM is 70, Gain is 70 dB and the GBW is about 1/3 of Different ,is that ok? and there is another phenomenon if I take a long time sim,the output wave will stable at  the common voltage,like this fingure A03))VP[(P[(3M~LC`GDMW8.png
发表于 2021-12-7 21:27:04 | 显示全部楼层
hanyongchunsd 发表于 2021-12-7 09:29
I have check it, my CMFB Loopgain PM is 70, Gain is 70 dB and the GBW is about 1/3 of Different , ...
so, what is your CMFB GBW and signal loop GBW and input signal frequency? maybe  CMFB GBW need more bigger than signal loop GBW.
GMT+8, 2025-12-22 16:02 , Processed in 0.021668 second(s), 4 queries , Gzip On, Redis On.
