查看: 1710|回复: 0
SNR
发表于 2021-11-18 22:22:31 | 显示全部楼层 |阅读模式
module SNR_Calculate(
input               i_clk             ,
input               i_rst             ,
input               i_mod_data_valid  ,
input signed[7:0]   i_mod_data        ,
input       [6:0]   i_SNR_data        ,
output              o_cal_snr_valid   ,
output signed[15:0] o_cal_snr_tx_data ,
output signed[11:0] o_cal_snr_dac_data
  reg        [6:0] r0_randn_address = 7'd0;
  reg        [6:0] r_randn_address  = 7'd0;
  reg              rd_randn_rom_en  = 1'b0;
  wire signed[7:0] w_randn_data ;
  randn_rom randn_rom_inst (
.address ( r0_randn_address ),
.clock   ( i_clk            ),
.rden    ( rd_randn_rom_en  ),
.q       ( w_randn_data     )
   always @(posedge i_clk)begin
      if(i_rst)begin
        r_randn_address <= 7'd0;
  rd_randn_rom_en <= 1'b0;
   end
      else if(i_mod_data_valid)begin
     rd_randn_rom_en <= 1'b1;
        r_randn_address <= r_randn_address + 1'b1;
   end
      else begin
      end
   end
     r0_randn_address <= r_randn_address;
   reg signed [7:0] r0_mod_data;
   reg signed [7:0] r1_mod_data;
   reg signed [7:0] r2_mod_data;
   reg        [3:0] r_mod_data_valid;
     r0_mod_data       <= i_mod_data ;
  r1_mod_data       <= r0_mod_data;
  r2_mod_data       <= r1_mod_data;
     r_mod_data_valid  <= {r_mod_data_valid[2:0],i_mod_data_valid};
   end
    wire signed[18:0] w_snr_data;
    snr_rom snr_rom_inst (
.address ( i_SNR_data   ),
.clock   ( i_clk        ),
.q       ( w_snr_data   )
   wire signed[26:0] w_snr_randn_data = w_snr_data*w_randn_data;
   wire signed[19:0] w_r2_mod_data    = (r2_mod_data <<< 12);
   reg signed[27:0] r_cal_snr_data  = 28'sd0;
   reg signed[27:0] r0_cal_snr_data = 28'sd0;
      if(i_rst)
         r_cal_snr_data  <= 28'sd0;
      else if(r_mod_data_valid[2])
         r_cal_snr_data <= w_r2_mod_data + w_snr_randn_data;
      else
   end
   assign o_cal_snr_valid    = r_mod_data_valid[3]    ;
   assign o_cal_snr_tx_data  = (r_cal_snr_data >>> 12);  //压缩成16bit,串口输出
   assign o_cal_snr_dac_data = (r_cal_snr_data >>> 16);  //压缩成12bit,dac输出
endmodule
GMT+8, 2025-12-28 22:26 , Processed in 0.013725 second(s), 4 queries , Gzip On, Redis On.
