查看: 1345|回复: 0
[招聘] 优质高薪数字设计工作机会
发表于 2021-11-15 10:37:28 | 显示全部楼层 |阅读模式
资深MCU ASIC设计工程师(北京、上海、武汉均有岗位)
联系方式:
Tel:13310878819   Wechat:ivy13310878819
Senior ASIC Design Engineer(MCU)
JOB DESCRIPTION:
This position is for a digital-MCU design engineer to build next-gen automotive MCU chipsets.
As part of the MCU design team, the design engineer will mainly focus on following areas, but not limited to:
-Define the architecture and functional blocks for the automotive MCU products, with appropriate HW/SW partitioning;
-Provide detailed technical documentation with specifications, block diagrams, and requirements to stakeholders
-RTL coding to verify against circuit implementation; Perform integration into MCUs.
-Automotive functional safety related design and document
-Maintain the 3rd party IP from vendor and verify functions by creating test cases.
-Assist with chip bring up and perform silicon/FPGA functional/performance validation.
-Assist with automotive functional safety (ISO26262) certification
-Assist with backend team on perform place-and-route and timing analysis of modules
-Assis with software team to develop software/firmware applications.
-Assist closely with different departments/stakeholders including Digital/Analog Design, Application/Test Engineering, & Reliability/Operations to resolve design, application, or test issues.
JOB REQUIREMENTS:
- Master’s degree in electrical engineering, computer engineering or related technical fields
- Good background in C, Verilog, SystemVerilog and verification methodology.
- A high-level of self-motivation and a proactive approach to solving problems.
- Familiar with AMBA AXI/AHB/APB spec.
- Familiar with ARM based MCU or SOC system design
- Familiar with the frontend ASIC design methodology/flow.
Solid knowledge in one of the following areas is a plus:
-Knowledge of ARM cortex M or cortex R's MCU or SOC architecture;
-Knowledge of automotive function safety (ISO26262) design;
-Knowledge of security design;
-Knowledge of low power design;
-Knowledge or design experience of CAN_FD/LIN/USB/Ethernet/UFS/eMMC/EFALSH Controller;
GMT+8, 2025-10-20 03:11 , Processed in 0.014286 second(s), 4 queries , Gzip On, Redis On.
