悬赏50资产已解决
新手上路烦请各位大佬请教多谢!
**WARN: (IMPCCOPT-1183): The library has no usable balanced buffers for power context:power_domain auto-default and effective power_domain auto-default, while balancing clock_tree SYS_MCLK_generator_for_SYS_CLK<8>. If this is not intended behavior, you can specify a list of lib_cells to use with the buffer_cells property.
**WARN: (IMPCCOPT-1184): The library has no usable balanced inverters for power context:power_domain auto-default and effective power_domain auto-default, while balancing clock_tree SYS_MCLK_generator_for_SYS_CLK<8>. If this is not intended behavior, you can specify a list of lib_cells to use with the inverter_cells property.
**ERROR: (IMPCCOPT-1135): CTS found neither inverters nor buffers while balancing clock_tree SYS_MCLK_generator_for_SYS_CLK<8>. CTS cannot continue.
**WARN: (EMS-27): Message (IMPCCOPT-1183) has exceeded the current message display limit of 20.
To increase the message display limit, refer to the product command reference manual.
**WARN: (EMS-27): Message (IMPCCOPT-1184) has exceeded the current message display limit of 20.
**WARN: (EMS-27): Message (IMPCCOPT-1135) has exceeded the current message display limit of 20.
Clock tree balancer configuration for clock_tree SYS_MCLK_generator_for_SYS_CLK<12>:
Non-default CCOpt properties for clock tree SYS_MCLK_generator_for_SYS_CLK<12>:
route_type (leaf): default_route_type_leaf (default: default)
route_type (trunk): default_route_type_nonleaf (default: default)
route_type (top): default_route_type_nonleaf (default: default)
Validating CTS configuration done.
**ERROR: (IMPCCOPT-2196): Cannot run ccopt_design because the command prerequisites were not met. Review the previous error messages for more details about the failure.
1
*** Summary of all messages that are not suppressed in this session:
Severity ID Count Summary
ERROR IMPCCOPT-1135 44 CTS found neither inverters nor buffers ...
ERROR IMPCCOPT-2196 1 Cannot run ccopt_design because the comm...
WARNING IMPCCOPT-1183 44 The library has no usable balanced %ss f...
WARNING IMPCCOPT-1184 44 The library has no usable balanced %ss f...
*** Message Summary: 88 warning(s), 45 error(s)
**ccopt_design ... cpu = 0:00:00, real = 0:00:01, mem = 1164.5M, totSessionCpu=0:01:10 **
innovus 17> ccopt_design -cts
2.有时候ccopt_design -cts 时innovus 软件会退出,烦请各位大佬帮忙解答
最佳答案
查看完整内容
看一看 UG吧。重点可以仿照着UG中
Design Implementation Capabilities -> Clock Tree Synthesis -> Flow and Quick Stat -> Quick Start Example
这个部分的内容,一步一步配置一下,然后跑跑看。
