查看: 7505|回复: 9
讲述VHDL仿真数模混合的方法
发表于 2007-12-24 19:51:48 | 显示全部楼层 |阅读模式
讲得挺好的,很容易懂。有兴趣的可以借鉴一下
Analog and Mixed-Signal Extensions to VHDL.pdf
140.66 KB, 下载次数: 59 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-12-25 15:01:15 | 显示全部楼层
发表于 2007-12-25 17:34:24 | 显示全部楼层
kankan
发表于 2007-12-25 23:03:53 | 显示全部楼层
看看吧
发表于 2007-12-25 23:16:50 | 显示全部楼层
kankana ~~~~~
发表于 2008-7-22 09:21:45 | 显示全部楼层
谢谢楼主
发表于 2008-7-25 01:37:32 | 显示全部楼层
什么平台下的?
是用什么平台?
头像被屏蔽
发表于 2008-8-18 11:05:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2012-8-24 17:21:29 | 显示全部楼层
一篇文章:
Abstract. Hardware description languages (HDL) such as VHDL are today an essential technology to support
most of the steps of digital hardware design, such as simulation, synthesis, testing, and formal proof. As the IEEE
1076 standard, VHDL is committed to evolve through ®ve years re-standardization cycles whose objective is to
make the necessary language changes or extensions in response to feedbacks from users and from tool suppliers.
Requirements to support analog and mixed-signal systems have been issued during the initial phases of the second
VHDL re-standardization cycle. Due to the complexity of the topic, a separate IEEE working group, referenced as
1076.1, was formally formed in 1993 with the charter to provide a language proposal based on VHDL 1076 that
includes these new requirements. The language design phase is now complete and a solid language architecture is
de®ned. A formal IEEE balloting process to approve the proposal as the new IEEE Standard 1076.1 has started in
August 1997 and will be completed before the end of the year. This paper presents an overview of the 1076.1
language proposal that enhances VHDL to handle systems that exhibit continuous behavior over time and over
amplitude. The way it is designed, VHDL 1076.1 will support the description and the simulation of both nonconservative
and conservative continuous and mixed discrete/continuous systems.
发表于 2013-3-11 19:30:34 | 显示全部楼层
谢谢楼主!
GMT+8, 2025-12-15 20:24 , Processed in 0.021496 second(s), 6 queries , Gzip On, Redis On.
