查看: 2944|回复: 2
求救,help ATAPI驱动
发表于 2007-12-20 17:34:49 | 显示全部楼层 |阅读模式
小弟为一DVDROM写ATAPI驱动,检测到硬件无措后,执行TestUnit(0x00)测试命令,发现发出packet命令后,向data寄存器写入12个字节的内容后,中断中检测到错误,错误码是0x20,或0x60,请高手指点,在线等,如需详细信息,我可以把代码发上来,
 楼主| 发表于 2007-12-20 17:43:53 | 显示全部楼层
这是发送packet(0xa0)命令的函数,请各位大虾帮忙,偶得qq是285611790,可加我,多谢了
*  SendPacketCommand()
*        Output:   0 -> success
*              other -> fail,redo
unsigned char SendPacketCommand(unsigned char dmamode)
unsigned i;
unsigned char status,bug,err_status;
BYTE4 timeout;
timeout = ATAPI_TIME_OUT_VALUE;
*      wait for device free                         *
while(1)
  status = _ATA_ReadRegister(ATAPI_REG_STATUS);
   if(!(status & ATAPI_BSY_BIT_MASK)&& !(status & ATAPI_DRQ_BIT_MASK))
       break;
  if( --timeout == 0)
      return(1);
*    initial Atapi task file here                 *
_ATA_WriteRegister( ATAPI_REG_FEATURE, dmamode &0xff);
_ATA_WriteRegister(ATAPI_REG_BCOUNTL,0x00);
_ATA_WriteRegister(ATAPI_REG_BCOUNTH,0x08);
_ATA_WriteRegister( ATAPI_REG_DRVSEL, 0xa0);
_ATA_WriteRegister( ATAPI_REG_CONTROL, 0x08);
*    Send packet command opcode 0xa0              *
RESEND_A0:
_ATA_WriteRegister( ATAPI_REG_COMMAND, ATA_POCKETE_COMMAND);
Wait_nBusy();
*     Wait for DRQ flag , max 3ms from 0xa0 sent  *
  while(1)
     if((status & (ATAPI_BSY_BIT_MASK|ATAPI_DRQ_BIT_MASK)) == ATAPI_DRQ_BIT_MASK) //bsy = 0,drq = 1
   break;
   /* if DRQ does not assert 3ms after 0xA0 sent, resend 0xA0 */
     if(--timeout == 0){
         goto RESEND_A0;
*      Send 12 bytes command data                 *
for (i = 0; i < 12; i += 2)
  _ATA_WriteRegister(ATAPI_REG_DATA, (gAtapi.command[i+1] << 8) | gAtapi.command );
//此处响应中断,检测到错误
Wait_us(200);
  return 0;
 楼主| 发表于 2007-12-21 14:12:22 | 显示全部楼层
没有人解答吗,好失望啊,
GMT+8, 2025-12-19 10:27 , Processed in 0.026416 second(s), 7 queries , Gzip On, Redis On.
