发表于 2007-12-20 22:23:41
显示全部楼层
下次请LZ贴出来!谢谢!
Chapter 1 System related design issues for low-voltage low-power CMOS analog circuit design 1.1 Introduction .................................................................................................................. 4 1.2 Limits to Low Power for Analog Circuit Design ......................................................... 4 1.2.1 Fundamental Limits ........................................................................................ 4 1.2.2 Practical Limits ............................................................................................... 7 1.2.3 Other obstacles to low-power ......................................................................... 8 1.2.4 Implications of supply voltage reduction........................................................ 9 Chapter 2 General notes on the design of low-voltage, low-power operational amplifier cells 2.1 Introduction to low-voltage low-power CMOS circuits.............................................. 11 2.2 Design Issues .............................................................................................................. 11 2.3 Low Voltage Analog Design Condsiderations ........................................................... 12 2.3.1 Introduction................................................................................................... 12 2.3.2 Classification of CMOS low-voltage circuits................................................ 12 2.4 Electrical Properties of MOS transistors .................................................................... 13 2.4.1 Strong Inversion............................................................................................ 13 2.4.2 Weak Inversion ............................................................................................. 15 2.4.3 Moderate Inversion ....................................................................................... 16 2.5 Rail-to-Rail Signals ..................................................................................................... 17 2.5.1 The Inverting Amplifier................................................................................ 17 2.5.2 Non-Inverting Amplifier Configuration ....................................................... 18 2.5.3 Summary of Amplifier Configurations......................................................... 18 2.6 Rail-to-rail stages ........................................................................................................ 19 Chapter 3 Input stage design of low-voltage, low-power operational amplifier design 3.1 Introduction ................................................................................................................ 20 3.2 Single Differential Input Stage................................................................................... 20 3.3 Rail-to-Rail Input stage ............................................................................................... 23 3.4 Constant gm rail-to-rail input stages .......................................................................... 30 3.4.1 Rail-to-rail input stages with current based gm control................................ 30 Chapter 4 Output stage design of low-voltage, low power operational amplifiers 4.1 Introduction ................................................................................................................ 38 4.2 Common-Source Output Voltage ............................................................................... 38 4.3 Class AB output stages............................................................................................... 41 4.4 Feedforward class AB output stages .......................................................................... 45 4.5 Feedback class AB output stage ................................................................................. 51 List of References ........................................................................................................55 |
