查看: 5443|回复: 1
[讨论] Design index
发表于 2021-9-17 09:20:52 | 显示全部楼层 |阅读模式
Adjacent wire minimum space requirement 25
BCB...................................................................... 4
Bond target location(s) on lead (terminal)requirements 26
Bondpad dimensional requirements for APG 10
Bondpad Dimensional Requirements for Die to Die Wirebonding  12
Bondpad Dimensional Requirements for Discretes 10
Bondpad fillet defined....................................... 4
Bondpad Layout DimensionalRequirements       10
Bondpad metal layerconstruction requirements 6
Bondpad passivation opening to seal ring.... 8
Bondpad passivation opening to unrelated metal minimum clearance      8
Bondpad pitch definition.................................. 4
Bondpad Placement........................................ 7
BSOB................................................................... 4
Buildsheet Requirements.............................. 34
Corner Exclusion Rule................................... 15
DAP...................................................................... 4
DAP edge distance to center of downbond or substratebond    27
Definitions and notes........................................ 4
Die Attach Paddle.............................................. 4
Die edge defined............................................... 4
Die edge to DAP edge minimum clearances 29
Die ID................................................................... 4
Die Identification/Step CodeRequirements 19
Die Placement Rules..................................... 29
Die rotation on DAP or die attach area........ 31
die size
how to measure........................................... 19
Die size
Prescribed increments................................ 19
Die size defined................................................. 4
Die Size Requirements................................. 19
Die to die gap for multiple die on single DAP, epoxydie attach 30
Die to die gap, Discrete’s assembly requirements    30
Discretes........................................................... 30
Downbond defined............................................ 4
Dual row bondpad option................................. 9
Fine Pitch defined............................................. 4
Fine Pitch note on buildsheets..................... 34
Graffiti.................................................................. 4
Ground bond.................... See Substrate Bond
Kelvin pad orientation..................................... 14
Kelvin Sense Pad defined............................... 4
Kelvin, trim, or zap padrequirements....... 13
Lead bond on the terminal min distance to edge      26
List of Figures................................................... 35
List of Tables.................................................... 34
Master and Option ID requirements............. 19
Master ID............................................................. 4
Maximum inboard bondpad............................. 7
Maximum wire formula for multiple bonds on terminalsor leads       33
Maximum wirelength over the die................. 20
Maximum wires per leadtip (terminal) width 26
Microprobe test padpassivation openings 15
Minimum adjacent wire to wire spacing requirement forsubstrate bond 28
Minimum bondpad metal enclosure of bondpad passivation      13
Minimum seal ring width................................ 16
MLP...................................................................... 4
Option ID............................................................. 5
PADGEN RULESET and CAD DRCSummary 40
parallel bondpads.............................................. 9
Passivation overlap requirement.................. 16
pin one bondpad requirements................. 15
PITCH CAPABILITY BYwire/PACKAGE TYPE 39
Purpose............................................................... 2
Saw street......................................................... 18
Saw street defined............................................. 5
Saw street passivation opening.................... 16
Saw Street Requirements............................ 18
Scope................................................................... 2
Seal Ring ConstructionRequirements forAPG Products      16
Seal ring defined............................................... 5
Seal ring metal width...................................... 16
Section 8 values summary spreadsheet..... 31
Staggered bondpads......................................... 9
Substrate Bond Defined................................... 5
Tiebar defined.................................................... 5
Wafer level CSP layout rules......................... 6
wire diameter.................................................... 33
Wire length die to lead, by package type and wirediameter 20
Wire length measurement.............................. 20
Wire space defined............................................ 5
Wire to adjacent leadtip minimum clearance requirement    25
Wirebond Related Rules.............................. 20
Wirebond target requirements for substrate bond ordownbond 27
Wirebond target requirements for wirebond to DAP orsubstrate die attach area       27
Wirebonding to tiebar...................................... 27
Worked loop wirebond defined....................... 5
发表于 2022-5-20 10:42:57 | 显示全部楼层
好课题啊,不能沉
GMT+8, 2025-12-25 15:22 , Processed in 0.013168 second(s), 4 queries , Gzip On, Redis On.
