发表于 2022-11-15 10:57:58
显示全部楼层
The directory GENERIC_tutorial contains
GENERIC_tutorial
|--> design_data --> Contains designs specific inputs given to Redhawk
| |--> def --> Contains the def files for the design
| |--> lef --> Contains the lef files for the design
| |--> lib --> Contains the .lib for the design
| |--> apl
| | |--> stdcells_apl --> Contains the cell.current file
| | |--> stdcells_aplcap --> Contains the cell.cdev file
| | |--> stdcells_aplpwcap --> Contains the cell.pwcap and decap_cell.pwcap file
| | |--> switch.model
| |--> ploc --> Contains the pad location file
| |--> timing --> Contains the timing file containing Slew and Timing window information
| |--> spf --> Contains the spef file for the design
| |--> gds2def --> Contains the def and lef files for the gds2def macros
| |--> tech --> Contains the technology file.
| |--> vcd --> Contains the input vcd file.
| |--> package --> Contains package file
| |--> esd --> Cotains esd rule files and std cell list
|--> static_run
| |--> setup.csh --> Script to set APACHEROOT, PATH and LM_LICENSE_FILE.
| |--> run_static.tcl --> Command file for the static run
| |--> GENENRIC.gsr --> GSR file pointing to all input files and also containing some preset variables
|--> dynamic_run
| |--> run_dynamic.tcl --> Command file for the static run
|--> scripts --> Contains perl scripts to generate switch voltage and switch current histograms
| |--> plot_switch_histogram1.pl*
| |--> plot_switch_histogram2.pl*
| |--> plot_switch_histogram3.pl*
| |--> plot_switch_histogram4.pl
| |--> align_waveforms.pl - Script for unit conversion and presim alignments.
|--> fao | |--> dynamic_mesh_optimize - Contains the Tcl script to run mesh_optimize
| |--> dynamic_mesh_optimize_taper - Contains the Tcl script to run mesh_optimize
| |--> dynamic_mesh_fix - Contains the Tcl script to run mesh_optimize
| |--> dynamic_mesh_sub_grid - Contains the Tcl script to run mesh_optimize
| |--> dynamic_decap_remove - Contains the Tcl script to run decap_remove
| |--> dynamic_decap_fill - Contains the Tcl script to run decap_fill
|--> low_power
| |--> Mixed mode analysis. Contains the Tcl and gsc file
|--> CPM
| |--> cpm_run - CPM creation in RedHawk. Contains the gsr and tcl file
| |--> power_transient_mode
| |--> resonance_aware_mode
| |--> user_configurable_mode
| |--> icpm
|--> early_analysis
| |--> lab1
| |--> static_prototype - An experiment to analyze the IR impact. Contains gsr,gsc and the run tcl file
| |--> dynamic_prototype - An experiment to analyze the IR impact. Contains gsr,gsc and the run tcl file
|--> signalEM -Contains the command file and GSR file for a signalEM run
|--> vcd_run - Contains the run tcl and GSR file for the worst power and worst dvd cycle runs
|--> package_run - Contains the dircetories for the run with RCLK package & S-paramter package
|--> esd_run - Contains the README and run directories for esd anlayis runs
|--> Excel2IR - Contains the required files to run the Excel2IR flow
