查看: 2634|回复: 4
[求助] Techgen转qrc error
发表于 2021-8-30 17:58:11 | 显示全部楼层 |阅读模式
执行 Techgen -simulation *.ict时,发现程序无法结束?产生如下error
sh: line0: source: call_nebula: file not found
请问这个有没有解决方法?
发表于 2022-5-18 18:44:30 | 显示全部楼层
请问您问题解决了吗?
发表于 2025-8-12 10:12:58 | 显示全部楼层
这个问题我也遇到了,请问有人解决了吗?
发表于 2025-10-1 00:25:49 | 显示全部楼层
Hello, I've also encountered this problem. Have anyone solved it?
I want to generate the qrcTechFile for TSMC 180nm.
Thanks & Best Regards
发表于 2025-10-1 00:26:39 | 显示全部楼层
Hello, I've also encountered this problem. Have you solved it?
GMT+8, 2025-11-1 00:09 , Processed in 0.019126 second(s), 3 queries , Gzip On, Redis On.
