查看: 1762|回复: 0
[求助] 综合完之后的Log里有这些warning,有知道是什么原因引起的吗?
发表于 2021-8-25 14:09:41 | 显示全部楼层 |阅读模式
  warning : the database contains a field that the reader does not support. [DATABASE-103]
                    : Unsupported data skipped.
  warning : Recommended data is not found. [PHYS-61]
                      : No power domain bounding box information found.
                      : The recommended data is not given and the tool uses the default value. Although the data is not mandatory, it is highly recommended to provide it in order to achieve the best result. Return the command after supplying the data.
GMT+8, 2025-12-23 10:15 , Processed in 0.010877 second(s), 3 queries , Gzip On, Redis On.
