查看: 2937|回复: 1
[求助] vivado调用vcs-mx 出错,Internal error: could not unlock message library mutex
发表于 2021-8-24 13:53:15 | 显示全部楼层 |阅读模式
悬赏1000资产未解决
没有用过vcs,在vivado里调用vcs-mx 仿真 srio,求助下面的vcs出错是什么情况
#22 0x000000000042b13d in _start ()
*** FATAL: Simulation stopped due to anerror (please see above in the log for more details)
The simulation cannot be continued. Thecurrent simulation state can be observed in DVE/UCLI.
Process VmPeak: 505896 kb, VmSize: 505892kb
System Free Memory: 193396 kb, System FreeSwap: 8252916 kb
No context available
Internal error: could not unlock messagelibrary mutex (No such file or directory)
发表于 2021-8-29 12:27:35 | 显示全部楼层
这个问题,我前几天遇到了。解决思路,首先检查VCS的License(有许多莫名其妙的问题,80%是因为License过期导致的),具体可以使用SCL工具验证下,然后再dve启动下。其次,如果不是License问题,检查下环境变量和VCS-MX的版本号,Vivado联合VCS仿真版本很有关系。
GMT+8, 2025-9-13 04:42 , Processed in 0.010517 second(s), 3 queries , Gzip On, Redis On.
