查看: 3355|回复: 2
[求助] synopsys 报warning求问 VER-318
发表于 2021-8-9 22:21:33 | 显示全部楼层 |阅读模式
小白求问,写代码在Xilinx vivado都没报啥错,放synopsys DC里面就报了个
Warning:  /home/IC/my_work/rtl/raw_fine_time_remap_and_encoder.v:22: signed to unsigned conversion occurs. (VER-318)
Warning:  /home/IC/my_work/rtl/raw_fine_time_remap_and_encoder.v:20: signed to unsigned conversion occurs. (VER-318)
代码如下:
`timescale 1ns/1ns
module raw_fine_time_remap_and_encoder #(
        parameter INPUT_DATA_WIDTH=18,
        parameter DIVIDER=1
        input  [INPUT_DATA_WIDTH-1:0]data_in,
        output data_out
`include "function_define.v"
localparam OUTPUT_VALID_DATA_WIDTH = divide2_repeat(INPUT_DATA_WIDTH, DIVIDER);   //这个值算出来是9
localparam DATA_STEP = exp2 (DIVIDER); //这个值是2
wire [OUTPUT_VALID_DATA_WIDTH-1:0]data_in_after_sampled;
genvar ii;
generate
        for (ii = 0; ii < OUTPUT_VALID_DATA_WIDTH; ii=ii+1) begin : decomposition_inst
                assign data_in_after_sampled[ii] = $unsigned(data_in[DATA_STEP*(ii+1)-1]);   // 这里是第20行
        end
endgenerate  //这是第22行
assign data_out = ^data_in_after_sampled;
endmodule
求大神指导哪儿出问题了
发表于 2021-8-10 10:02:32 | 显示全部楼层
只是个严格的警告,fpga工具本来就不严格。
 楼主| 发表于 2021-8-10 22:12:07 | 显示全部楼层
感谢回复,自己慢慢查已经找到问题,问题在循环变量里面,相乘出现了有符号数和无符号数相乘,所以才出的问题
GMT+8, 2025-12-22 02:37 , Processed in 0.015722 second(s), 3 queries , Gzip On, Redis On.
