查看: 3332|回复: 6
[求助] 文章下载求助
发表于 2021-7-17 11:12:31 | 显示全部楼层 |阅读模式
悬赏20资产未解决
题目是A novel higher-order interpolative modulator topology for high resolution oversampling A/D converters
地址是
https://www.researchgate.net/publication/243771477_A_novel_higher-order_interpolative_modulator_topology_for_high_resolution_oversampling_AD_converters
发表于 2021-7-17 13:11:33 | 显示全部楼层
others ??
higher order topology for interpolative modulators for oversampling A/D converters
higher order topology for interpolative modulators for oversampling AD converter.pdf (947.07 KB , 下载次数: 13 )
 楼主| 发表于 2021-7-17 13:39:41 | 显示全部楼层
peterlin2010 发表于 2021-7-17 13:11
others ??
thx! but that's not what I wantI need this :<<A novel higher-order interpolative modulator topology for high resolution oversampling A/D converters>> ,a MIT thesis by Wai Laing Lee (1987)
 楼主| 发表于 2021-7-17 13:57:43 | 显示全部楼层
others ??
thx! but that's not I want.
I need this: A novel higher-order interpolative modulator topology for high resolution oversampling A/D converters----a MIT Master thesis(1987) by Wai Laing Lee
发表于 2021-7-17 20:15:39 | 显示全部楼层
kankan
发表于 2021-7-18 23:02:51 | 显示全部楼层
good topic
thanks for share~
发表于 2021-7-21 16:27:16 | 显示全部楼层
看看
GMT+8, 2025-12-28 10:35 , Processed in 0.018460 second(s), 5 queries , Gzip On, Redis On.
