查看: 6532|回复: 7
[求助] MIPI D-PHY SoT Error and SoT Sync Error
发表于 2021-7-14 19:21:27 | 显示全部楼层 |阅读模式
求助
最近在看MIPI D-PHY Spec v1.2. Spec中定义了Fault Detection的内容。其中有两项是:
SoT Error: The Leader sequence for Start of High-Speed Transmission is fault tolerant for any single-bit error and some multi-bi errors. Therefore, the synchronization may be usable, but confidence in the payload data is lower. If this situation occurs an SoT Error is indicated.
SoT Sync Error: If the SoT Leader sequence is corrupted in a way that proper synchronization cannot be expected, a SoT Sync Error is indicated.
SoT Sync Error,我理解是receiver没有正确接收到transmitter发送的Sync sequence “00011101”,从而上报错误。
那么SoT Error怎么理解?
 楼主| 发表于 2021-7-15 10:56:14 | 显示全部楼层
各位大神有了解的吗?
发表于 2021-7-23 16:32:32 | 显示全部楼层
SoT error 就是 DPHY Rx settle 与 Tx Preppare + Zero 时间不匹配时
 楼主| 发表于 2021-8-18 10:16:53 | 显示全部楼层
协议里面关于SOT定义的Error有两种,一种是SOT Error. 一种是SOT Sync Error。请问你知道两者的区别,每太看懂这个
发表于 2021-8-23 17:13:07 | 显示全部楼层
D-PHY 應該算是穩定IP , 有做bit shfit 應該可以解出SOT
发表于 2022-11-17 13:23:12 | 显示全部楼层
bit shift是移位解析sot序列吗?
发表于 2023-3-22 23:09:51 | 显示全部楼层
是的
发表于 2023-3-27 22:12:31 | 显示全部楼层
多谢分享
GMT+8, 2025-12-25 08:26 , Processed in 0.128810 second(s), 4 queries , Gzip On, Redis On.
