查看: 7183|回复: 16
[求助] 启动vc_static时遇到的问题
发表于 2021-7-4 08:59:05 | 显示全部楼层 |阅读模式
是没有装license造成的吗?请问license该如何破解和安装呢?谢谢!
发表于 2021-7-4 18:20:22 | 显示全部楼层
不是
 楼主| 发表于 2021-7-4 20:10:18 | 显示全部楼层
那是什么原因啊?亲赐教,谢了
发表于 2021-7-4 21:59:14 | 显示全部楼层
这软件干啥用的?
发表于 2021-7-5 09:17:01 | 显示全部楼层
求分享vc static, 谢谢。
发表于 2021-7-5 16:01:40 | 显示全部楼层
也有这个问题,不知解决了没
发表于 2021-8-8 12:45:40 | 显示全部楼层
这个是网络的问题,好像要用IPV6
发表于 2021-11-16 17:31:18 | 显示全部楼层
亲,解决了吗,我也出现了这个问题
发表于 2021-11-16 20:25:33 | 显示全部楼层
You need to have an internet connection to communicate with sqlite database. If you're running in a virtual machine, create a host-only adapter. If you're running in an isolated machine (no network) it will not work.
If you're runnin vc static connected to the internet and still no access to local db, then the port needed for the db is blocked in your router.
Best way to work with vc formal (and any other cracked tools) is by running a virtual machine with a host only mode network.
发表于 2021-11-29 01:17:04 | 显示全部楼层
@dqwuf2008  楼主,后来解决了吗
GMT+8, 2025-12-21 03:46 , Processed in 0.028486 second(s), 7 queries , Gzip On, Redis On.
