查看: 2616|回复: 2
[求助] ARM的stdcell 如何加到IC617
发表于 2021-7-1 15:01:09 | 显示全部楼层 |阅读模式
SMIC40LL的ARM标准单元库提供到了OA格式的库,添加的时候,提示:
*WARNING* (TECH-2000152): The attached technology library 'techlib_logic0040ll' for design library 'sc9mc_base_rvt_c40' was not found.
      Attach an existing technology library to the design library or define the missing technology library 'techlib_logic0040ll' in your cds.lib file.
      The default technology file will be used.
*WARNING* Missing Masters:
    Library      Cell       View
    armPrimitive inv        symbol
    armPrimitive invz       symbol
    armPrimitive nfet4      symbol
    armPrimitive pfet4      symbol
    armPrimitive pins       input
    armPrimitive pins       output
    armPrimitive pins       vdd
    armPrimitive pins       vnw
    armPrimitive pins       vpw
    armPrimitive pins       vss
    armPrimitive tg         symbol
    armPrimitive titleBlock symbol
    armPrimitive wire_c     symbol
Loading schematic.cxt
Loading ddui.cxt
Loading vb.cxt
Loading nt.cxt
Loading oi.cxt
Loading see.cxt
Loading treeAssistant.cxt
Loading asst.cxt
Loading le.cxt
Loading drdEdit.cxt
Loading hsm.cxt
Loading lx.cxt
Loading lce.cxt
Loading rte.cxt
Loading oasis.cxt
Loading simui.cxt
Loading layerProc.cxt
*WARNING* (DB-270172): dbGetAnyInstMaster: Failed to open cellview armPrimitive/pins/input because cellView database does not exist.
Loading apAssist.cxt
*WARNING* (DB-270172): dbGetAnyInstMaster: Failed to open cellview armPrimitive/pins/vss because cellView database does not exist.
Loading cph.cxt
这个怎么办呢?
发表于 2025-5-26 19:31:20 | 显示全部楼层
后来搞定了么?
发表于 2025-11-10 20:50:44 | 显示全部楼层
楼主您好,请问后来这个问题解决了吗?我也是smic40往virtuoso里面导入数字库的时候一样的报错内容
GMT+8, 2025-12-13 09:51 , Processed in 0.016620 second(s), 5 queries , Gzip On, Redis On.
