查看: 1666|回复: 1
[求助] icc2这两个APP——option有什么区别
发表于 2021-6-4 16:23:49 | 显示全部楼层 |阅读模式
1  route_opt.flow.enable_targeted_ccd_wns_optimization
Specifies  whether  targeted  concurrent clock and data optimization is
       enabled in the route_opt command. Enabling  targeted  concurrent  clock
       and  data optimization helps setup timing closure on user-specified end
       points and/or path groups.
2oute_opt.flow.enable_ccd
Specifies  whether concurrent clock and data optimization is enabled in
       the route_opt command. Enabling concurrent clock and data  optimization
       helps setup timing closure.
发表于 2021-6-4 17:50:57 | 显示全部楼层
第二个选项是开启ccd opt,第一个选项是定义wns是多少的path用ccd opt去修复,比如你可以定义-100ps,那么就是-100ps一下的路径会用ccdopt去优化,大概就是这样。
GMT+8, 2025-10-8 16:30 , Processed in 0.012464 second(s), 4 queries , Gzip On, Redis On.
