查看: 3700|回复: 4
cadence数模混合仿真报错,请添加原目录文件到cds.lib中
发表于 2021-5-23 11:26:18 | 显示全部楼层 |阅读模式
“balabala”(库名)was originally compiled with logical name  “balabala_old”(旧的库名)。 please include the original definition of library “balabala_old”(旧的库名) in cds.lib file
解决方案:删除库目录下的“pak”文件,如“inca.inx8664.150.pak”(一个压缩包文件),重新启动cadence即可
Francesco,
In your library directory, there will be an outdated "pak" file. Something like
inca.lnx86.165.pak
(there may be more than one).
Please delete the pak files.
If a library is renamed, the pak file remains, but contains information about
the old library name. As a result, when ncvlog tries to compile the verilog code
(needed to analyse it to identify pin names and so on), it can't because there's
a mismatch between the logical name (Sinan, which is what the library was
previously called, presumably) and the current name (Francesco?).
Regards,
Andrew.
发表于 2021-5-23 12:43:50 | 显示全部楼层
对库重命名后引发的错误,库重命名后,但残留了编译期间产生的含原库名的底层文件
回复 支持 2 反对 0
发表于 2024-7-15 16:36:16 | 显示全部楼层
确实管用,这个pak文件在库目录里面。删掉就好了。
发表于 2024-12-26 16:53:14 | 显示全部楼层
太厉害了
发表于 2025-1-9 18:48:37 | 显示全部楼层
解决了 斯国一
GMT+8, 2025-11-7 07:50 , Processed in 0.015328 second(s), 3 queries , Gzip On, Redis On.
