查看: 1973|回复: 1
centos6.5 vcs2014.3运行出错,求解决办法
发表于 2021-5-22 11:31:08 | 显示全部楼层 |阅读模式
悬赏10资产未解决
11 modules and 0 UDP read.
        However, due to incremental compilation, no re-compilation is necessary.
make[1]: Entering directory `/home/IC/project/pj/apb_sram/uvm_apb_sram-master/sim/csrc'
rm -f _csrc*.so linux_scvhdl_*.so pre_vcsobj_*.so share_vcsobj_*.so
ld -m elf_i386 -shared -o .//../simv.daidir//_csrc0.so SIM_l.o 5NrI_d.o 5NrIB_d.o
ld -m elf_i386 -shared -o .//../simv.daidir//pre_vcsobj_1_1.so --whole-archive pre_vcsobj_1_1.a --no-whole-archive
if [ -x ../simv ]; then chmod -x ../simv; fi
g++  -o ../simv  -m32 -m32   -Wl,-rpath-link=./ -Wl,-rpath='$ORIGIN'/simv.daidir/ -Wl,-rpath='$ORIGIN'/simv.daidir//scsim.db.dir  uvm_dpi.o  _csrc0.so  pre_vcsobj_1_1.so  rmapats_mop.o rmapats.o rmar.o           /opt/Synopsys/VCS2014/linux/lib/libzerosoft_rt_stubs.so /opt/Synopsys/VCS2014/linux/lib/libvirsim.so /opt/Synopsys/VCS2014/linux/lib/librterrorinf.so /opt/Synopsys/VCS2014/linux/lib/libsnpsmalloc.so    /opt/Synopsys/VCS2014/linux/lib/libvcsnew.so /opt/Synopsys/VCS2014/linux/lib/libuclinative.so   -Wl,-whole-archive /opt/Synopsys/VCS2014/linux/lib/libvcsucli.so -Wl,-no-whole-archive       ./../simv.daidir/vc_hdrs.o    /opt/Synopsys/VCS2014/linux/lib/vcs_save_restore_new.o /opt/Synopsys/VCS2014/linux/lib/ctype-stubs_32.a -ldl -lm  -lc -lpthread -ldl
uvm_dpi.o: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make[1]: *** [product_timestamp] Error 1
发表于 2021-5-25 22:33:59 | 显示全部楼层
看下log里 uvm_dpi.o是怎么生成的,是不是生成了64位的版本,指定 -CFLAGS "-m32 "试试
GMT+8, 2025-12-23 00:57 , Processed in 0.011374 second(s), 3 queries , Gzip On, Redis On.
