我看同一份文档,发现前后文出现了一些貌似矛盾的说法
1.At the same time, supply voltages and transistor threshold voltages have been lowered,
causing leakage current to become a significant problem
2.The most basic way to reduce power is to reduce the supply voltage. Power usage is
proportional to the square of the supply voltage, as the simple example in Figure 1-4
demonstrates. A 50 percent reduction in the supply voltage results in a 50 percent reduction
in current and a 75 percent reduction in power. A similar degree of power reduction can be
achieved in CMOS circuits for both dynamic and static power.
