专注IC的猎头 手上有多家公司的设计 验证 dft 后端等等职位
以下是三家公司的ATE职位,欢迎问询 微信:361261541
Test Engineer(电源芯片)Job Responsibilities: Ø Work with designteam to understand design specifications. Ø Generate testplan, create test, qualification and characterization program, design ATEhardware interface boards. Ø Debugcharacterizing silicon on ATE, correlate results with bench data. Ø Analyze siliconresults, supporting failure analysis tasks. Ø Performstatistical analysis of yield fallout, debug, and fix yield issues; optimizetest time. Ø Work withproduction team to release products to volume production. Ø Test strategydefinition and implementation the methodology on new product test development Ø ATE (AutomaticTest Equipment) test hardware and software. Ø Silicon qualification& characterization including qual hardware development. Ø Drive for robustand cost-effective test solutions while being accountable for product quality. Qualifications: Ø ATE experience(ETS364, ETS88, STS8200, QT8200, QT8100, S100, Chroma), although Eagle/QT8200experience is preferred and is a differentiator. Ø Characterizationtest program and hardware development experience, Production test program andhardware development experience Ø Strong technicalknowledge of electronic devices and circuits, and Mixed Signal test techniques Ø Data analysisskills using equivalent tool based on STDF. Ø Experience withproduct engineering activities such as yield improvement and test timereduction. Ø Strongunderstanding of the IC product development process, from concept to volumeproduction Ø Experienced withtest program and hardware offload to manufacturing sites. Ø Revision controltools experience: Subversion, Git Ø Demonstratedstrong analytical and problem-solving skills. Ø Ability to workin teams and collaborate effectively with people in different functions. Ø Strong timemanagement skills that enable on-time project delivery Ø Demonstratedability to build strong, influential relationships. Ø Ability to workeffectively in a fast-paced and rapidly changing environment. Ø Ability to takethe initiative and drive for results. Ø Experienced withvarious lab equipment such as scopes, power supplies, source meters, etc. Pre-requisite Skills/Requirements: Ø Bachelor of orabove in Electrical and Electronics Engineering. Ø 5+ years of ICtesting relevant experience. Ø English &Mandarin language skills for both writing and speaking. Ø Familiar withC/C++, Pascal, or any tester programming language.
Senior ATE Test Engineer(GPU)
Job Overview:
The candidate will be responsible for Iluvatar products NPI development in ATE engineering area. Candidate should have a strong understanding of ATE S/W & H/W, Test program development, trouble shooting, IC Characterization and Qualification. As the role of Sr. Test Engineer, we expect you could be self-motivated, creative thinking and good communication skills.
Duties/Responsibilities:
? ATE test program development for NPI on UFLEX, 93K, J750 or other ATE platforms and release for production
? ATE Load board and Probe card design for NPI on UFLEX, 93K, J750 or other ATE platforms
? Trouble-shooting and test coverage improvement on ATE
? Manage IC Product bring-up, testing, validation, characterization, qualification and release for production
? Lead RMA debug and QA/SLT reject debug and drive product quality improvement
Qualifications:
? BS or above in EE/ME, Minimum 5 years’ experience in ATE test engineering or product engineering
? Experienced with ATE SW and HW development on UFLEX, 93K, J750 or other similar ATE platforms
? Experience with IC manufacture flows, wafer processing, testing, and qualification
? Experience of driving product SKU and binning strategy as a plus
? Proficient use of lab instruments/tools as a plus
? Be familiar with VB, C/C++, Perl/Python scripting language as a plus
? Experience of Server type high power/high speed IC products as a plus
? Highly motivated, fast learner, team player with good communication skills
产品测试工程师(GPU)
工作职责
?与设计,验证和DFT团队合作,将设计概念转换为产品测试要求,开发文档,负载板和插座设计规范以及ATE测试程序。
?开发用于工艺/电压/温度(PVT)边界,信号和供电完整性表征的高性能IC测试矢量,并参与芯片调试,电气故障分析(EFA)和物理故障分析(PFA)。
?开发高速模拟和数字接口测试方法,并实施ATE测试,characterization程序。
?与合作伙伴一起制定IC可靠性测试程序和风险产品筛选程序,
?分析测试数据,建立产品交付的制造要求和规范,并努力缩小整个产品供应链中潜在的测试差距和相关性问题。
工作要求
? 电子工程或微电子工程学的BS/MS/Phd。
? 具有超过5年的半导体芯片测试经验
? 熟练用于数字/模拟电路的测试矢量生成,并有平衡测试时间与测试覆盖范围的经验
? 有使用芯片测试和表征的自动测试设备的经验,包括93K。
? 具有分析模拟PHY知识,例如眼图,jitter,浴盆曲线, s参数测量等
? 具有芯片产品测试数据分析和提升良品率方面的经验
