查看: 10821|回复: 18
[求助] AMS仿真报错
发表于 2021-3-22 11:41:51 | 显示全部楼层 |阅读模式
AMS仿真报错但是信息提示里并没有error,请问这是什么错误,提示信息如下:
INFO (AMS-2142): The AMS Unified Netlisting (AMS UNL) flow has been enabled.
INFO (AMS-2031): The instances bound to the views specified in the 'Netlist using spectre CDF simInfo'
field in the Netlister form (Simulation->Options->Netlister) will be netlisted as
analog primitives using the Spectre CDF simulation information.
Begin Netlisting Mar 22 11:39:37 2021
WARNING (OSSHNL-143): Incremental netlisting is not possible since the global map file '/home/zzz/simulation/AandD/ams/config/netlist/digital/ihnl/globalmap', could
not be opened in the read mode for IHNL version number comparison. Therefore
re-netlisting the entire design.
INFO (VLOGNET-60): The stimulus name mapped table will not be printed in the
"/home/zzz/simulation/AandD/ams/config/netlist/digital/testfixture.verilog" file. To print the stimulus name mapped table, set
simVerilogPrintStimulusNameMappingTable = t either in CIW or the .simrc file
before invoking Verilog netlister.
INFO (VLOGNET-62): Database internal net names will be printed for floating instance ports. To prevent
them from being printed, set simVerilogProcessNullPorts = t either in CIW or
the .simrc file.
INFO (VLOGNET-64): All cellviews in the design will be printed in the Netlist Configuration list.
If you want to print only those cellviews that need to be re-netlisted in the
list, set simVerilogIncrementalNetlistConfigList = t either in CIW or the
.simrc file.
INFO (VLOGNET-68): The initial state of stimulus of all inout pins is set to "z". To get inout
pins with initial state of "0", set hnlVerilogIOInitStimulusStr = "0"
either in CIW or the .simrc file.
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
*ERROR* (AMS-1247): AMS UNL netlisting has failed.
Check Simulation->Output Log->Netlister Log for errors.
Correct your design and netlist again.
      ...unsuccessful.
发表于 2021-3-23 13:54:25 | 显示全部楼层
按照提示
你会发现有ERROR信息的!
发表于 2021-3-25 09:41:35 | 显示全部楼层
我和您一样情况,请问您解决了嘛
发表于 2021-3-25 10:58:58 | 显示全部楼层
Begin Netlisting Mar 25 10:52:52 2021
map file
'/home/meow/simulation/tb_test/ams/config/netlist/digital/ihnl/globalmap',
could
Therefore
"/home/meow/simulation/tb_test/ams/config/netlist/digital/testfixture.verilog"
the .simrc file.
Configuration list.
re-netlisted in the
in CIW or the
.simrc file.
"z". To get inout
发表于 2021-3-25 12:12:42 | 显示全部楼层
我刚刚解决了这个问题,asm仿真软件版本太低了
发表于 2021-5-17 21:35:05 | 显示全部楼层
那你是怎么解决的呢,升级就可以吗
发表于 2021-5-17 21:40:09 | 显示全部楼层
大佬 你这个问题解决了吗
发表于 2021-6-22 16:34:04 | 显示全部楼层
解决了吗?How
发表于 2021-7-4 19:22:42 | 显示全部楼层
同问如何解决
 楼主| 发表于 2021-7-5 20:07:03 | 显示全部楼层
xyf333 发表于 2021-7-4 19:22
同问如何解决
这是在我自己电脑上装的virtuoso上仿真时报的错,至今没有解决,然后我用学校的服务器,同样的操作过程就没有报错,所以我觉得是我自己安装的问题。
GMT+8, 2025-9-17 07:29 , Processed in 0.025785 second(s), 5 queries , Gzip On, Redis On.
